1978 - 1996 Big Bronco
Help Bronco won't start!!!!
Old Nov 9, 2006 | 09:59 PM
Daz-man's Avatar
Daz-man
Okay I have a 1980 bronco with a 351M and a Duraspark II ignition. The wife was driving it and it died while it was running off the original coil. I took the Omni pak off because it was sparking around the lead wire but it worked fine.
Now I have an after market coil (Jacobs Omni Pak) and the original coil is still installed so this is what I did.
1. Replaced ignition module with another one but won't start;
2. while cranking it over no spark with coil or Omni pak;
3. if I put the key forward to accessory, before it cranks, the Omni pak provides spark;
4. put the key past this point so it cranks the engine and the spark stops.
Any ideas? I'm just lost on this one because I get no spark out of the coil or the Omni pak while the engine is cranking.
Old Nov 10, 2006 | 09:42 AM
Kemicalburns's Avatar
Kemicalburns
I would install a stock coil, check the cap/rotor as well. possible the distributor is toast?
Old Nov 10, 2006 | 05:29 PM
robins79 custom's Avatar
robins79 custom
i had a very similar problem with my 79 bronco,it would turn over but no spark,I changed every electrical part related i could think of including my wire-ing harness, the only thing i never checked was the distributer and that was the problem all along. So I would say start there.
Old Nov 10, 2006 | 06:36 PM
Daz-man's Avatar
Daz-man
I get 12V to the + side of the coil and 1.5V on the other side.
Ideas?
Old Nov 10, 2006 | 08:36 PM
Aciancio's Avatar
Aciancio
If you loose spark when the key is in the start position but can get spark in the on position it sounds like you might have a problem with the ignition switch down on the steering column
Old Nov 11, 2006 | 01:13 AM
Daz-man's Avatar
Daz-man
Well I replaced the stator in the distributor and still the same problem.
Replaced the ignition module and she fired right up!
Thanks for the responses guys.
Old Nov 16, 2006 | 04:27 PM
PerfDistIgnition's Avatar
PerfDistIgnition
FTE Sponsor
Distributor
If you decide to get a new distributor, consider our D.U.I.-Davis Unified Ignition or our custom curved Duraspark distributor. Please see them at:
http://www.performancedistributors.com/forddui.htm
<O
__________________
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
