After market water temp gauge
I did a search and either I'm not understanding it, or just plain confused.
We picked an aftermarket temp gauge for the sons truck.
I understand that we can put it in the factory location at the back of the block which omits the factory gauge. However we would like to keep that gauge active as well.
We read where some 5.0 guys put it in/by the thermostat.
Does that read properly and have any of you done this?
First picture is of the factory sensor pulled out.
Second picture is of the thermostat housing.
Third picture is of probe in the housing.
I have used both locations. The location in the thermo housing will read about 20 hotter than at rear of block. Block will show temp of coolant coming in, whereas the thermo will reveal temp of heated coolant leaving the engine.
I would say to buy a good gauge. The SunPro brand fails every 1-2 years. The present Summit catalog has AutoMeter gauges for $60!
Well the gauge is currently in the thermostat housing port as posted in previous pictures. After we do some more run time, I'll follow up. I am thinking about switching the senders around. Move the factory sender from the back of the block to the thermostat housing and vice versa. The aftermarket gauge has only so much length for the probe and we are using all of it to reach the front of the engine. Not sure I like how tight it is.
I took the stock one out, wires broke. So I put a mechanical one in, AutoZone cheapo. It reads what I believe to be correct. Thermostat opens at about 190 and drops down to about 160 and then runs at 180 all day on the highway at 2800rpms lugging 33" tires. That's the plug in the front of the block
