Water Temp Gauge Problem
Old May 8, 2013 | 01:03 PM
thedickens01's Avatar
thedickens01
I have a problem with my 2005 F250 6.0. The problem is with my temp gauge. When I tow my 25 foot 5<sup>th</sup>wheel, the chime in the instrument cluster dings. In about 30seconds the temp gauge goes from normal to hot. I slow the truckdown to about 20 mph for about 60 seconds and the gauge returns to normal. I can stop the truck and open the hood and the engine does not seem to be hot. Any Ideas??
Old May 8, 2013 | 03:08 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Do you have white speckles all over the area around the recovery coolant jug? Sounds to me like your oil cooler is clogged...... Do you have any gauges other than the normal Ford idiot ones?
Old May 8, 2013 | 06:11 PM
thedickens01
No white speckles and the truck has only ford factory gauges.
Old May 8, 2013 | 06:16 PM
MC5C's Avatar
MC5C
I'd get a Scangauge so I could read the actual temps. Then I'd get a infrared temp gun so I could take actual temperatures. I'd get it hot and see if the temp on the thermostat housing matched what the computer and the sensor thought the temp was. It's probably a bad sensor, but until you test, you don't know. The factory gauge is useless, you need to read the OBDII data.
Brian
Old May 8, 2013 | 07:30 PM
69cj's Avatar
69cj
Swap the ect/eot sensors and see if the problem moves. They are interchangeable.
Old May 8, 2013 | 07:48 PM
04badford's Avatar
04badford
Not to get you too worried but , when the heads poped the factory gauge Never gave me any warning , untill I looked in the pasenger mirror and seen a cloud of misty white coolent smelling, then it was too late I even hydro locked when I tryed to start and move the truck , so those gauges are very Important.
Aug 8, 2012 09:44 AM
nico963
Apr 5, 2010 10:52 AM
Opossum
Dec 16, 2008 11:01 AM
rcknrbn
2004 - 2008 F150
33
Dec 10, 2006 10:31 PM
willym
Nov 21, 2005 10:33 AM
