Injector question.
Injector question.
Let me fill in some of the details.
I went against my own rules and got some thing from China.
The VCMII and the IDS to go with it. (I know BAD SEAN)
Anyway to my injector question. I have seen a bit of stiction when cold
out side and the engine is cold. Once it warmed up seems all good.
Well today I went out any played with the VCMII and ran the power balance
test and the uncompensated one also. What I saw was the #8 injector was
really dipping down at 1200RPM high idle. At normal idle the line was flat.
The engine was not fully warmed up. It was at about 130º~150º EOT
Once I find out how to save the movies I will post the screen.
So the question is take #8 out and clean it or just replace it?
BTW FICM is a nice solid 48 V.
Sean
Sean
The jumpy #8 settles down after it is warmed up.
I'll have to go back and look at the saved live data
to check bit I did see some of the others getting a
bit bumpy after it warmed up.
I think that pulling and cleaning is going to be in the project
list for this spring. If and when it quits raining every day.
I have a supplier I can order from.
Not bad if your only going to use now and then.
It did not come with the wireless or the flight recorder.
I know that the flight recorder can be ordered with it.
PM me if you want some more info.
Sean
Sean
Little kid (boy) next door is going to come over and say
"What's you doing mister?" I will answer with
"Polishing my spools" Where was I going with that?
Anyway back to the question. I guess I should run the relative
compression test also. Not that having unhappy injectors won't
skew it somewhat. At least I think it would a bit. I may be wrong.
Sean
Sean
