1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
shackles vs. spring packs
Old 03-20-2014, 10:40 AM
NTENSE's Avatar
NTENSE
NTENSE is offline
Originally Posted by EXv10
Blocks in the front? By mini-packs do you mean the little short spring pieces?
Nah, no blocks in the front. Just in the back. And yes mini packs being the little short minis with the rod or bolt through them.
  #32
Old 03-20-2014, 12:44 PM
EXv10's Avatar
EXv10
EXv10 is offline
Those are expensive garbage and unsafe in the front, plus they do nothing for spring clearance.
  #33
Old 03-20-2014, 05:15 PM
NTENSE's Avatar
NTENSE
NTENSE is offline
I was gonna go with 2" lift shackles up front for tire clearance.
  #34
Old 03-27-2014, 08:57 PM
big specht's Avatar
big specht
big specht is offline
As for front blocks being so bad. Why is about every heavy duty truck with front leaf springs have a lift blocks?? If you dont think so look at the next heavy truck you see. AND those trucks dont have track bars to center the axle. Just my .02 on this topic.
  #35
Old 04-14-2014, 09:59 AM
SuperDutyScaler's Avatar
SuperDutyScaler
SuperDutyScaler is offline
well my two truck's don't. 1995 GMC Top Kick 37k GVW no blocks up front leaf sit right on the front axle, 2005 Freightliner 37k GVW front leafs sit on axle
  #36
Old 04-14-2014, 11:38 AM
EXv10's Avatar
EXv10
EXv10 is offline
They probably don't want novices using blocks (not saying you are.) Those blocks you see probably have well fitted holes and pins in them etc.
dillinewton
18
01-24-2010 08:18 PM
crazer42
03-14-2009 03:10 PM
Bowie
23
12-30-2008 02:37 PM
Shade
09-22-2008 12:29 AM
cowboyty
11-10-2006 06:11 AM
Quick Reply: shackles vs. spring packs
