Flippin shackles
Old Jan 21, 2010 | 04:44 PM
dillinewton's Avatar
dillinewton
Flippin shackles
Does anyone know how many inches flipping shackles would give me?
Old Jan 21, 2010 | 04:48 PM
Hickfied's Avatar
Hickfied
About 4" of lift.
Old Jan 21, 2010 | 05:15 PM
montana_highboy's Avatar
montana_highboy
The shackle flip only yeilds half its length in lift because you're only relocating one end of the spring pack so it only nets about 2" in actual lift.
Old Jan 21, 2010 | 05:19 PM
Hickfied's Avatar
Hickfied
He can also move it forward and make his own shackles to get the 4in.
Old Jan 21, 2010 | 07:25 PM
bronkntrukholik's Avatar
bronkntrukholik
I flipped my shackles on my '79 bronco and put 4" coils up front and sits pretty level and clears 38.5's!
Old Jan 21, 2010 | 07:29 PM
dillinewton
do you flip both or do you just flip on or exactly how do you do it?
Old Jan 21, 2010 | 08:37 PM
bronkntrukholik
This is how i did mine, it may not be the shackle flip everyone else was talking about, but I used a donor frame and pulled the front spring hanger of the leafs (in front of the rear axle) and flipped it upside down and installed it inplace of the old rear spring hanger (behind the axle) I had to make a couple new mounting holes to do this, it has been about 3 years since i did, you need to get the correct position so you have the correct position for your spring shackle to work correctly along with the rear suspension. Like I mentioned this gave me about 4" of lift. Do your research before starting this or any lift, make sure it is done safely and properly! I am only giving a brief description of this, it gets to be a lil complicated figuring out the new proper angles!
Old Jan 21, 2010 | 09:52 PM
Hickfied's Avatar
Hickfied
One way to do it is to remove both rear shackle mounts of the rear leaf springs. Swap them from side to side (drives to pass, pass to drivers) and flip the shackle mount upside down. If I recall correctly, they use the same holes. You will only have about $10 in bolts.
You may want to check pinion angle, but with only that much movement, it shouldn't be to bad.
Old Jan 21, 2010 | 10:20 PM
dillinewton
thanks alot does anyone have any ideas of how to catch up with the rear cause im getting 9 inch coil srings so can go anymore on that unless someone makes custom ones? thanks alot
Old Jan 21, 2010 | 10:38 PM
clhart426's Avatar
clhart426
how much lift does that give when you go from drivers to passenger and passenger to drivers? or is that the "2-4" you guys are talking about? i thought a shackle flip was ordering new ones?
Old Jan 21, 2010 | 10:42 PM
Fordworth's Avatar
Fordworth
Here's how I did mine. Similar to what Hickfied said but If I was to use the same holes they would have hit the under side of the bed. Sooo, I used the lower holes and added a piece of angle bar under each frame rail and dropped the hangers down yielding more lift. I'm including a pic of my home built front hangers too.
Old Jan 24, 2010 | 12:37 AM
dillinewton
im going to flip my shackles so does anyone have ideas how to get the front to sit up even? thanks
Old Jan 24, 2010 | 12:40 AM
Hickfied's Avatar
Hickfied
Get 4" coils, adjustable track arm, 4* C bushings, and a drop pitman arm. If you are into fabbing now is the time to extend your radius arms to allow for better flex.
Old Jan 24, 2010 | 01:03 AM
clhart426's Avatar
clhart426
so does swapping from drivers to passenger and then turning them upside down really work with the same holes and 4" of lift?
Old Jan 24, 2010 | 06:45 AM
dillinewton
oo sorry i didnt say what i already have. i have 9 inch coils with 9 inch leafs, and 3 body lift but i just want 2 or more inches
