shackles vs. spring packs
I have an '03 7.3 CC 4wd with 35/12.50's on it. I have the front leveled by way of an extra leaf spring from the local spring shop. I like the way my truck looks right now but my tires scrub my fenders (not the liners but the rear corners of the fender flares) under very little compression. I was curious what the pros and cons were to each.
my understanding of it is that shackles will change your caster and depending on how big they are can effect your pinion angle, i went with spring packs, theyre all over ebay for around 100 bucks with u bolts. ive heard a few horror stories of people shackling up the front and the drive shaft slides apart at the slip yoke leaving very little spline contact area and locking it in and stripping out the driveshaft... just my .02
running a mini pack on my current truck, trouble-free almost two years now. ran a lift shackle on my last super duty, along with 4" springs and had no ill-effects either. the caster/pinion angle concerns makes perfect sense in theory, but i literally couldn't tell any difference (and i wheeled that truck, wasn't a street queen).
It's hard to go wrong with springs packs. Shackles can open up a whole new can of worms like Airframes4life stated, and can end up costing more in the long run. Since shackle lift only give you half amount of lift, you are going to need a lot of shackle to get any decent lift. I think anymore than 2'' (1'' lift) of shackle is beginning to pushing it.
}> I would just use lift blocks and be done with it. }> Edit: The "lift blocks" was pure sarcasm. It is the absolute wrong way to do it. |
its illegal to run front blocks in ANY STATE plus DANGEROUS, just buy a 4" lift kit with new front springs and be done with it, plain and simple
Originally Posted by SuperDutyScaler
(Post 14160883)
It is still a bad idea though. |
I've been running 2.5" lift shackles (provided 2.5" of lift) for going on 4 years and 32k miles and half of that is running in 4x4 high during the winter every day for 6 months.
absolutely no issues with steering, front drive shaft..ect |
before i put my new pro comp 2.5" springs on i had the stock 4400lb front springs+tuff country 1.5" add a leaf+ 1" pro form lift shackle for almost four years and i never had any handling issues, other than a dump truck ride from the add a leaf. I changed the springs because i couldn't take the ride anymore and im debating adding my 1" lift shackle again to get me a little extra height up front
Originally Posted by AlaskanEx
(Post 14160893)
absolutely no issues with steering, front drive shaft..ect My experience with lift shackles on my old FJ40 is the extra side to side leverage they provide. It makes the death wobble more possible. |
stock on the bottom new lift shackle on tophttp://i57.photobucket.com/albums/g2...ent/015-10.jpg
http://i57.photobucket.com/albums/g2...ent/002-19.jpg before http://i57.photobucket.com/albums/g2...ent/005-23.jpg after http://i57.photobucket.com/albums/g2...ent/003-19.jpg |
Originally Posted by benfishn
(Post 14160851)
(Post 14160893)
Will spring packs effect the ride or handling? Another question I've had since researching this topic is in regards to lift blocks. If the main concern is them getting spit out, why would a bolt through the center like the spring packs not work?
Originally Posted by NTENSE
(Post 14161673)
In order to get the full 2" did you shackle both ends of the spring? Seems to me if you lift one end of the spring 2", by the time you go halfway back, where the axle is, you'd loose half the lift.
(Post 14161652)
By springs do you mean spring packs?
From my experience paying the extra to do it right the first time saves you money, time, frustration, and is safer. |
