I've replaced fuel tank, fuel pump, fuel filter. Truck still won't start without using starter fluid. Runs fine after starting. Any ideal what to change next to fix problem?
Does this only happen when it's cold, the engine I mean? If you go to the store to get a six-pack, does it start back up when you come out? Or do you have to use starting fluid always?
OK, try this, cycle the key a few times off and on, leaving it in the on position for at least 2 secs. Do this about 5 times and then try to start it. If it starts up, then you are losing residual pressure on the line and your pump is not strong enough to pump it up while cranking.
