Fuel Problem?
Old May 23, 2005 | 04:04 PM
Toad66's Avatar
Toad66
Fuel Problem?
I have a 95 F150 with a fuel injected V6. It has dual fuel tanks. When starting the truck it will only start from the rear tank. It will run from the front tank if the engine is running, but will start to hesitate like it is missing when under above 45mph. The engine also hesitates at certain speeds or when accelerating when using the rear tank, but not as bad as the front tank. Is this Fuel Pump, injectors, timing or a sign the end is near? any ideas?
Old May 23, 2005 | 06:03 PM
LxMan1's Avatar
LxMan1
Sounds like the front pump assembly is bad and the fuel filter could be partially clogged.
Old May 24, 2005 | 10:39 AM
Toad66's Avatar
Toad66
Fuel Prob.
Thats what I was thinking, just changed the fuel filter and it looked like it was a little crushed like it was being sucked from the inside..
