OK, I broke it
Old 12-20-2013, 06:40 PM
smallello's Avatar
smallello
smallello is offline
OK, I broke it
I have Vintage Air AC and it has a capilary tube on the control panel. Well, I broke it off the switch. What does it do?
I never use the heat only the AC. Can it work without it or do I have to replace the switch it was connected to?
Old 12-20-2013, 06:45 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
The compressor won't cycle if that is broken. Those switches aren't cheap, tho. Take the old one to an A/C shop and they can surely match it. Or...
NAPA -- THERMOSTATIC SWITCH
Old 12-20-2013, 06:54 PM
smallello's Avatar
smallello
I was afraid of that. Thanks!
Old 12-21-2013, 12:47 PM
smallello's Avatar
smallello
Looks like I can replace the entire panel for less than just the switch.
http://www.summitracing.com/parts/vt...-shq/overview/
Old 12-21-2013, 01:32 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Looks like they have other individual parts not listed, might be worth giving them a call.
Old 12-21-2013, 09:20 PM
smallello's Avatar
smallello
Yeah, I will give them a call on Monday.
Old 01-05-2014, 09:16 PM
smallello's Avatar
smallello
So I ended up replacing the whole controller.
The PO cut a hole in the dash for the stereo just under the cluster. I never really liked it there so I thought this would be a good time to move the AC controls to that spot.
I made a panel for the new controller so that it would cover the radio hole and hold the controller. I wanted the panel to be recessed so the the controller would sit flush in it. I used fleece and fiberglass resin to form it and painted it with a textured paint. It is a much better location for the controller.
Old 01-05-2014, 09:20 PM
topmoo's Avatar
topmoo
topmoo is offline
What a great solution! It really looks good, nice work!
Old 01-05-2014, 09:25 PM
The Horvaths's Avatar
The Horvaths
The Horvaths is offline
Job well done.
Old 01-05-2014, 11:03 PM
Bluey Zedoff's Avatar
Bluey Zedoff
Bluey Zedoff is offline
Looks a peach!
Old 01-05-2014, 11:24 PM
Chris 56 f6's Avatar
Chris 56 f6
Chris 56 f6 is offline
That my friend is a very nice fix.
Old 01-06-2014, 06:26 AM
Harrier's Avatar
Harrier
Harrier is offline
Wow great fix, that looks awesome.
Old 01-06-2014, 07:54 PM
smallello's Avatar
smallello
Thanks guys. Now I just have to get the console installed so I can get the stereo re-installed...
tshrager
04-09-2012 08:13 PM
jcs1966
09-07-2004 04:18 PM
TCinNH
1997 - 2003 F150
06-16-2004 05:35 PM
yvonne666
1997 - 2003 F150
04-24-2004 02:50 PM
damonlan
12-07-2003 12:16 AM
Quick Reply: OK, I broke it
