Sponsored by: Auxito
AC always on???
Old Jun 15, 2004 | 08:26 PM
TCinNH's Avatar
TCinNH
Question AC always on???
I have a 2003 Supercrew, 5.4L, auto. Is the air conditioner supposed to be on for all the switch positions on the vent control. The only time it appears to be off is when it is set to "Panel". In any other position it stays on. Is this normal?
Thanks.
Old Jun 15, 2004 | 08:52 PM
LxMan1's Avatar
LxMan1
It is only off on Panel and Floor it will run on all other positions (except off, of course)
Old Jun 15, 2004 | 10:13 PM
matr8er's Avatar
matr8er
That is one thing I don't like about mine. I only want the ac on when I have it on ac. I was disappointed when I found that out. If you want to defog your windsheild, I think the best way to do that is to get the inside the same temperature as the out side. Kind of hard to do that the way it is.
Old Jun 15, 2004 | 10:32 PM
LxMan1's Avatar
LxMan1
I guess they did this to keep the compressors moving and from seizing up. I don't like it either. The 2004's have a a/c button to control the compressor in any setting I think.
Old Jun 16, 2004 | 04:37 PM
dwestove4's Avatar
dwestove4
I have the same problem on my 03 supercrew. Is that true for all F150s of that year? Mine seems to be on pretty much on every setting around the dial. I can't tell how warm to set the thermostat to make it shut off. Wastes gas when you don't really need the AC but just want the fan on.
Old Jun 16, 2004 | 05:35 PM
LxMan1's Avatar
LxMan1
It must be in VENT or FLOOR or OFF to keep the compressor off. All other positions, it will run. I believe that all 97-03 F150's as well as SD trucks do this.
mrad
May 30, 2012 05:46 PM
jamesn_13
Mar 30, 2012 04:36 PM
montero91
Apr 27, 2011 06:09 PM
rvdealer
1997 - 2003 F150
Sep 11, 2007 09:29 AM
jimjima67
Computer Chips & Tuners
Dec 12, 2002 07:18 PM
