Dummy EGR?
Old 11-15-2013, 06:29 PM
pile_53574's Avatar
pile_53574
pile_53574 is offline
Question Dummy EGR?
Does anyone make a dummy EGR valve, one you can plug in, not operate and not throw a code?? Maybe its invention time!!
Old 11-15-2013, 06:54 PM
cheezit's Avatar
cheezit
cheezit is offline
its called a programer
Old 11-15-2013, 06:58 PM
jswartz84's Avatar
jswartz84
jswartz84 is offline
Most of us leave the egr valve in place and plugged in for proper cooling fan operation.
Old 11-15-2013, 07:05 PM
pile_53574's Avatar
pile_53574
Right, already have programmer, but does not shut off egr, so wondering if something else was available
Old 11-15-2013, 07:47 PM
Unrealo4's Avatar
Unrealo4
Unrealo4 is offline
Custom tunes by matt @ gearhead. All his tunes include egr being turned off by default.
Old 11-15-2013, 07:51 PM
MisterCMK's Avatar
MisterCMK
MisterCMK is offline
What tuner do you have?
Old 11-15-2013, 08:44 PM
Bullitt390's Avatar
Bullitt390
Bullitt390 is offline
Certified Thread Hijacker
Probably only looking at commanded EGR and not EGR error which would show -100% even though the commanded opening would for example be 28%
Josh
Old 11-15-2013, 09:03 PM
w_huisman's Avatar
w_huisman
w_huisman is offline
Ford 6 0 Diesel EGR Eliminator Spool w Clamps Bolts | eBay
Is this what you're looking for? I run with one, and leave the actual EGR valve plugged in and bolted to one of the intake elbow bolts.
Old 11-16-2013, 06:45 AM
pile_53574's Avatar
pile_53574
Yes, so EGR is still plugged in, but sitting on outside of motor still functional?? I knew someone would come up with this. Good price too. Thanks
Old 11-16-2013, 11:14 AM
cheezit's Avatar
cheezit
cheezit is offline
sct should give the option. mine does
Old 11-16-2013, 04:05 PM
texastech_diesel's Avatar
texastech_diesel
texastech_diesel is offline
Token Redneck
So you're going to just plug the hole for the valve? You're going to not address the actual problem which is the EGR cooler itself, or delete any of the components that have exhaust gas flowing through them, and instead shove the plug in the hole and leave the valve sitting out in the engine bay?
If you don't have inspections, why not just spend $40 more delete with a kit, or even less $ to weld up the cooler that's already in there, then you don't need the plug because there's no gas flow.
If you do have inspection, you're going to be pulling the plug to reinstall the valve annually anyways, why not weld the cooler and leave the valve in place?
Any way you cut it, you'll need a programmer that can kill the CEL or you'll have to buy a PCM flash from someone because simply removing the valve won't stop if from setting a P0401 insufficient EGR flow code.
Old 11-16-2013, 04:10 PM
Bullitt390's Avatar
Bullitt390
You can lead a dumb horse to water, but ya can't make him drink
Josh
mstiles19
08-09-2012 05:14 AM
basstardo
07-25-2012 10:32 PM
jagerbomber
07-04-2012 08:38 AM
blueline970
09-12-2011 05:14 PM
pnj442
09-29-2010 07:46 PM
Quick Reply: Dummy EGR?
