windshield wiper problems
Get a testlight. With the wipers on and the box clicking, go out and clip the testlight lead to a good ground, and then poke the green wire. It should have power.
Then poke the darkblue/orange wire. This is your low speed wire and should have power when the box clicks, or have power all the time when you are in regular low speed mode. The high speed wire is the white. If you are getting power everywhere, one more thing you can do is move your ground clip over and see if you can clip to the motor itself. I do not know about yours, but a lot of these motors are mounted in rubber mounts to lessen the noise, so they have to have a little ground jumper to ground the motor to the firewall. Make sure it's good. If you do not get any readings after moving your ground to the motor, the ground to the motor may be bad.
eg1031
04-09-2013 08:36 AM
Redneck1465
11-09-2006 04:18 AM
frugal boy
12-10-1999 06:45 AM
