wipers not working need help..
Old Apr 7, 2013 | 04:39 PM
eg1031's Avatar
eg1031
i have a 92 f150 inline 6 i just did a conversion to a 351 it came out of a 97 f250...
so i replaced the engine compartment harness and wiper motor everything works fine
but the wipers dont ..the old wiper motor was a 2 plug but now its a1 pug .
the old one was workin so it cant be nothing electrical inside and i already test the old motor on by other truck
Old Apr 8, 2013 | 12:55 AM
MeanGreen460's Avatar
MeanGreen460
Are you getting power to wiper motor? Did you check wiper fuse? Take a test light check for power on wire or plugin connector .Also check make sure wiper motor is grounded good .
Old Apr 8, 2013 | 04:06 PM
eg1031's Avatar
eg1031
I used my powerprobe to check the back of the plug and I have ground to both black wires and positive to the green... all of my fuses are good and I hear a clicking noise behind my glovebox
Old Apr 8, 2013 | 06:02 PM
MeanGreen460
On the Wire harness that plugs onto your wiper motor how many wires do you have .On my 95 F250 I have 6 wires .Does your truck have intermitten wipers?Maybe you should put your old wiper motor back on and rewire it .
Old Apr 8, 2013 | 10:13 PM
eg1031's Avatar
eg1031
the plug has 6 wires..
im not sure if i have intermitten wipers
if nothing works i may just try wiring it to switch
Old Apr 8, 2013 | 11:27 PM
Encho's Avatar
Encho
The Southernmost Mod
Behind the glove box is the control box of the wipers, if it's unplugged your wipers won't work.
Old Apr 9, 2013 | 08:36 AM
eg1031's Avatar
eg1031
Its plugged in I already replaced it and I hear it make a clicking noise when I change speed
dthut
Apr 28, 2017 09:42 PM
RonKrem
Mar 11, 2016 10:56 PM
dave2
Jan 30, 2008 02:55 PM
Redneck1465
Nov 9, 2006 04:18 AM
19F10059
May 11, 2002 10:54 PM
