CAM SENSOR PROBLEM
CAM SENSOR PROBLEM
DRIVING HOME FROM WORK TRUCK QUITS PULLED CODE WITH FLASH TUNER CPS ERROR CODE SO I CHANGED IT. DROVE IT TO WORK NEXT DAY SAME THING BUT WHEN COOLED OFF FOR A WHILE STARTED BACK UP WILL RUN FOR ABOUT 15 MINUTES AND WILL QUITE. FLASH TUNER SHOWS CPS ERROR CODE AND THEN SHOWS PCM KEEP ALIVE MESSAGE. PUT ANOTHER CPS JUST SAFE MEASURE AND SAME HAPPENS. ANY IDEAS 2002 F250 7.3.
RandyMann
06-18-2016 10:06 AM
chspyder
10-21-2004 05:18 PM
