CAM SENSOR PROBLEM
Old Sep 20, 2013 | 07:25 PM
HOTBOAT460's Avatar
HOTBOAT460
CAM SENSOR PROBLEM
DRIVING HOME FROM WORK TRUCK QUITS PULLED CODE WITH FLASH TUNER CPS ERROR CODE SO I CHANGED IT. DROVE IT TO WORK NEXT DAY SAME THING BUT WHEN COOLED OFF FOR A WHILE STARTED BACK UP WILL RUN FOR ABOUT 15 MINUTES AND WILL QUITE. FLASH TUNER SHOWS CPS ERROR CODE AND THEN SHOWS PCM KEEP ALIVE MESSAGE. PUT ANOTHER CPS JUST SAFE MEASURE AND SAME HAPPENS. ANY IDEAS 2002 F250 7.3.
Old Sep 20, 2013 | 07:44 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Put the first one you had back in and see if it works... or the second one. Might be the computer...
RandyMann
Jun 18, 2016 10:06 AM
KH85
Jan 3, 2014 10:53 PM
blrman1962
Mar 8, 2013 04:12 PM
JRB
Oct 23, 2006 04:38 PM
chspyder
Oct 21, 2004 05:18 PM
