PCM or CPS
Old Oct 22, 2006 | 10:40 PM
JRB's Avatar
JRB
PCM or CPS
Pulling down the drive tonight, the truck surged a little and the check engine light came on. I have a programer in it, so I checked the codes and it came up a P0603, PCM. I know sometimes a programer will cause this, although it has never done it before. Will a CPS do this, and if so, will it throw a code ? After I pulled in the garage and came back out a few minutes later, the check engine light went off. I went in a cleared the codes and set it back to stock program.
Old Oct 23, 2006 | 11:55 AM
Tenn01PSD350's Avatar
Tenn01PSD350
I don't have a programmer but I would say since you reset it, drive on and see if it occurs again. If it does, uninstall the programmer and see if it reoccurs. Then start the "Hunt". You do have a spare CPS right?
Old Oct 23, 2006 | 12:02 PM
JRB's Avatar
JRB
PCM or CPS
No, but I am going to acquire one, does the CPS throw an error code or can it be in the PCM code ?
thanks
Old Oct 23, 2006 | 04:27 PM
scooter80's Avatar
scooter80
I have a programmer and my CPS went bad a few days ago. The CPS DID throw its own code. I also have the constant "PCM memory" code. The CPS code is something like "intermittent CPS communication" or similar. But it DOES throw its own code.
Old Oct 23, 2006 | 04:38 PM
JRB's Avatar
JRB
Thanks scooter80, I put the program back to stock, started the truck and the service engine light went off, and I went in a cleared the codes. I guess I will drive it a little and hope for best.
Thanks to everybody for their response.
