window seals revisited a general call out
Old 02-13-2015, 12:49 AM
scoobyvanjack's Avatar
scoobyvanjack
scoobyvanjack is offline
Sorry been out of touch for a while. moved out to sin city shipped the van too.
(hopefully it will at some point handle a vacay drive back to MD. and back)
I was still fiddling around with a flat spot on mid range accel when we left MD. The old gal loves the change in altitude. She'll smoke the tires at near 40 mph.
SOoo has anything new evolved on the pop out window seals? I've about given up and will likely get the seals from macs for the fixed glass. now comes the fun part getting the glass out of the channels in one piece. Had to cut out a botched patch job upper half over the rt rr. wheel. Still need to shrink the pnl. before I form the new patch. A few pin holes and the outer skin will be ready for filler and final prep. started to try my hand at the upholstery. Bought left over fabric and tuned up and studied up on may aunts old zig-zag. stripped the drivers seat and made notes and saved the old parts for patterns. turns out its been re-done before ok to look at but did the best with what they had and was able to get a pre-made cover at the time. the passenger seat was still untouched beat to hell but unmolested. Remnant's of the listing wires. cords.burlap batting and foam still enough to recreate the original suspension of the seat griddle. I put a practice cover over it and will return to that later on. Well gotta git if anyone has any insights on the pop out seals please share.
Thanks
svj
Old 03-24-2015, 04:20 PM
alarmmedic's Avatar
alarmmedic
alarmmedic is offline
window seals
Hi. I was wondering the same things and have basically given up on the window seals. I glued my two old ones back together that the paint guy cut in pieces the other two he through out. I bought the only remaining one in the country from Nos after they lowered the price to 75 dollars. And for the missing window I bought some thick stick on foam weather stripping from space age auto paint store here in Mesa Az. It was a little thicker and harder to close the window but it closes easy. There are no leaks. You cannot tell from the outside but from the inside you can see the difference of the seals and looks tacky but it works and I have vented windows. I bought the outer seals that go on the window from tim brogan I believe his name was, I think from Tennessee. He was trying to get a company to make the seals that go on the frame of the door but it never materialized.
hivoltj
02-16-2017 07:21 AM
mustang_gt_350
08-05-2015 03:14 AM
Fishallot
1978 - 1996 Big Bronco
22
01-09-2012 02:20 PM
Rogue_Wulff
13
11-21-2010 05:25 PM
redrumybronco
07-08-2004 05:04 PM
Quick Reply: window seals revisited a general call out
