Performance Problem ~ Need HELP
My 2008 Ford F250 SD Diesel 6.4L problem.The truck runs great while it’s cold, but when it gets hot, code P0088 comes up, I re-set it, it runs good for a while, but the same code returns when it gets hot again. We changed the fuel filters, oil and EGR valve from the original 2 pipe system to a single coolant line and need to know how coolant lines should be hooked up. I have decided not to bypass the EGR system as some suggest. Any help will be greatly appreciated!
High pressure fuel pump.
See this recent post.
https://www.ford-trucks.com/forums/1262613-poo88.html
metalvolks
32
11-10-2014 08:25 AM
