oil issue or engine problem
Old 08-07-2013, 02:01 PM
dlanders71's Avatar
dlanders71
dlanders71 is offline
I just bought an '04 F150 from a friend. It has 250K miles on it. When I got the truck there were no tapping noises coming from the engine. Now that I changed the oil, at start up till about 5 miles down the road, I hear the tapping noise. I put Castrol high mileage 5W-20 in it. Could it just be the oil I'm using or something more expensive?
Old 08-07-2013, 04:19 PM
Nalb1221's Avatar
Nalb1221
Nalb1221 is offline
What kind of oil filter did you use?
Old 08-07-2013, 04:33 PM
dlanders71's Avatar
dlanders71
I believe they used a frame filter. I provided the oil.
Old 08-07-2013, 05:47 PM
Nalb1221's Avatar
Nalb1221
Nalb1221 is offline
That's your problem right there, you need to use a better filter. Motorcraft or wix. The frams tend to break up and clogg the screens. Frams are garbage it's all over these sites not to use those filters on these f150's. I would change immediately.
Old 08-07-2013, 06:02 PM
jr105's Avatar
jr105
jr105 is online now
It could be your Fram filter. They have a really cheap drain-back prevention valve that will let the oil drain back into the crankcase, so you get a dry start until the filter refills.
Another possibility is that, where it has 250k on it, your friend may have been running a heavier oil that would have made the engine run quieter.
Old 08-07-2013, 06:54 PM
dlanders71's Avatar
dlanders71
I'll give it a shot. Thanks for the input.
Old 08-07-2013, 06:57 PM
dlanders71's Avatar
dlanders71
I'll change the filter and hope that's the problem. It didn't make the noise until about a week after I took the truck. Meanwhile I'll find out what oil was used in it. Thanks
Old 08-08-2013, 09:47 AM
RISUPERCREWMAN's Avatar
RISUPERCREWMAN
RISUPERCREWMAN is offline
So many of the " Engine Noises" on the 3v 5.4's are attributed to several things.
1. People not using the proper viscosity engine oil. 5W-20 only!
2. People not using a MotorCraft FL-820-S FIlter only!
3. People not changing the oil frequently enough causing sludge issues!
I own two Modular engines in my 2008 F-150 5.4 3v, & my 2011 Crown Victoria 4.6
I use only Ford Motorcraft filters FL-820-S & a quality Synthetic oil, I use Amsoil & these two motors have 42K & 44K miles each & have run quiet & very strong!
Old 08-08-2013, 10:46 AM
jr105's Avatar
jr105
jr105 is online now
You didn't say which engine you have. 5.4 or 4.6?
Old 08-08-2013, 11:44 AM
cb_13's Avatar
cb_13
cb_13 is online now
Fram oil filters are not all bad but the cheap orange one is.
RAPR
6.2L V8
01-30-2012 11:25 AM
diesel_hillbilly
06-26-2009 09:46 PM
VanGo
Aerostar
12-18-2008 02:42 PM
Milwaukee1979F150
21
04-17-2008 10:28 AM
grey77
Oil & Lubrication
03-04-2005 09:11 PM
Quick Reply: oil issue or engine problem
