oil issue or engine problem
Old Aug 7, 2013 | 02:01 PM
dlanders71's Avatar
dlanders71
I just bought an '04 F150 from a friend. It has 250K miles on it. When I got the truck there were no tapping noises coming from the engine. Now that I changed the oil, at start up till about 5 miles down the road, I hear the tapping noise. I put Castrol high mileage 5W-20 in it. Could it just be the oil I'm using or something more expensive?
Old Aug 7, 2013 | 04:19 PM
Nalb1221's Avatar
Nalb1221
What kind of oil filter did you use?
Old Aug 7, 2013 | 04:33 PM
dlanders71's Avatar
dlanders71
I believe they used a frame filter. I provided the oil.
Old Aug 7, 2013 | 05:47 PM
Nalb1221's Avatar
Nalb1221
That's your problem right there, you need to use a better filter. Motorcraft or wix. The frams tend to break up and clogg the screens. Frams are garbage it's all over these sites not to use those filters on these f150's. I would change immediately.
Old Aug 7, 2013 | 06:02 PM
jr105's Avatar
jr105
It could be your Fram filter. They have a really cheap drain-back prevention valve that will let the oil drain back into the crankcase, so you get a dry start until the filter refills.
Another possibility is that, where it has 250k on it, your friend may have been running a heavier oil that would have made the engine run quieter.
Old Aug 7, 2013 | 06:54 PM
dlanders71's Avatar
dlanders71
I'll give it a shot. Thanks for the input.
Old Aug 7, 2013 | 06:57 PM
dlanders71's Avatar
dlanders71
I'll change the filter and hope that's the problem. It didn't make the noise until about a week after I took the truck. Meanwhile I'll find out what oil was used in it. Thanks
Old Aug 8, 2013 | 09:47 AM
RISUPERCREWMAN's Avatar
RISUPERCREWMAN
So many of the " Engine Noises" on the 3v 5.4's are attributed to several things.
1. People not using the proper viscosity engine oil. 5W-20 only!
2. People not using a MotorCraft FL-820-S FIlter only!
3. People not changing the oil frequently enough causing sludge issues!
I own two Modular engines in my 2008 F-150 5.4 3v, & my 2011 Crown Victoria 4.6
I use only Ford Motorcraft filters FL-820-S & a quality Synthetic oil, I use Amsoil & these two motors have 42K & 44K miles each & have run quiet & very strong!
Old Aug 8, 2013 | 10:46 AM
jr105's Avatar
jr105
You didn't say which engine you have. 5.4 or 4.6?
Old Aug 8, 2013 | 11:44 AM
cb_13's Avatar
cb_13
Fram oil filters are not all bad but the cheap orange one is.
RAPR
6.2L V8
Jan 30, 2012 11:25 AM
diesel_hillbilly
Jun 26, 2009 09:46 PM
VanGo
Aerostar
Dec 18, 2008 02:42 PM
Milwaukee1979F150
21
Apr 17, 2008 10:28 AM
grey77
Oil & Lubrication
Mar 4, 2005 09:11 PM
