p0012 code on newly rebuilt engine
Old Feb 1, 2012 | 09:23 AM
gizmo64's Avatar
gizmo64
04 lariat 5.4l was just rebuilt. idles rough at stoplights and p0012 comes up. I think the mechanic may have valve timing off? A high output oil pump was installed when engine was rebuilt. Could this be causing the code.
Old Feb 1, 2012 | 09:56 AM
antony25's Avatar
antony25
engine may be mis-timed or bank one vct solenoid may be stuck.
Old Feb 1, 2012 | 10:02 AM
gizmo64's Avatar
gizmo64
Could this have anything to do with the high output oil pump?
Old Feb 1, 2012 | 10:18 AM
antony25's Avatar
antony25
unlikely as oil flow to the phasers is controlled by the solenoids.
Old Feb 1, 2012 | 10:31 AM
gizmo64's Avatar
gizmo64
The vct solynoids are new so Im going to check the valve timing.
Is there a esier way to check this than to remove the timing cover?
Old Feb 1, 2012 | 10:37 AM
antony25's Avatar
antony25
best thing to do is remove timing cover since incorrect timing is suspected.
Old Feb 1, 2012 | 10:45 AM
gizmo64's Avatar
gizmo64
Thanks, im going to tear into it right now. I appreciate the input.
Old Feb 1, 2012 | 10:52 AM
antony25's Avatar
antony25
another possible cause is that the phaser locating dowel is sheared off or missing. were the phasers replaced or removed?
Old Feb 1, 2012 | 11:34 AM
FORDSVTPARTS's Avatar
FORDSVTPARTS
Former Vendor
Were the timing chain tensioners replaced? I've heard of a few issues with those.
Old Feb 1, 2012 | 12:06 PM
gizmo64's Avatar
gizmo64
Yes chains phasers tentioners. All new.
Old Feb 1, 2012 | 01:10 PM
antony25's Avatar
antony25
You say the engine was rebuilt. Were the cylinder heads replaced? Damaged cam journals are the most common problem with this engine. Loss of oil pressure from worn journals will cause cam timing problems due to excessive oil pressure loss in the cylinder head.
Old Feb 1, 2012 | 01:57 PM
gizmo64's Avatar
gizmo64
Yes the heads,cams,vct solidiods,camphasers,.have all been replaced.
I have another question. I bought a scanner to retrieve the codes. My mechanic lives over 100 miles away. The first time the engine started running rough at a stop light was about 75 miles after the rebuild. Iwas on my way home from my mechanics. Istepped on the accelerator a little and it came right out of it. The next day the service engine light came on. I pulled the codes they were p0022,p0340,and p0345. At this point the camposition sensers were the only thing that was not replaced. So I replaced them. This didnt seem to affect the way it ran at a stoplight but it brings up codes p0012 sometimes and p0022 sometimes.
My question is could this be a computer problem?
Any input would be very appreciated,
Thank you
Old Feb 1, 2012 | 02:24 PM
antony25's Avatar
antony25
unlikely the computer is the problem. Sound like a hot oil pressure issue. Recommend oil pressure test at hot idle. 25 psi minimum to operate vct system.
Old Aug 8, 2013 | 05:07 PM
jaymay75's Avatar
jaymay75
Did you ever figure out this problem. I rebuilt my engine and got a P0012
thegalindo1985
2004 - 2008 F150
13
May 17, 2014 01:28 PM
Bowser Two
May 8, 2010 02:03 PM
ghz
Dec 17, 2005 06:08 PM
Rada
1997 - 2003 F150
Nov 10, 2001 10:56 PM
