Using AE to check UV wiring harness
Old 07-21-2013, 11:03 AM
ScottInTexas's Avatar
ScottInTexas
ScottInTexas is offline
Give me coffee - Or beer!
How do I use the AE scanner to check the under valve cover wiring harness? I have no check engine light, but something is not right. I am only getting 11.8 mpg. It takes forever to warm up, but unless you let it warm up for a long time it runs like crap. New ICM, new cam sensor. I bought the AE for stuff like this, but I am having trouble learning to use it.
Old 07-21-2013, 11:08 AM
carltonwebb's Avatar
carltonwebb
carltonwebb is offline
I think You can do a buzz test to check is the circuit complete to the injectors. Beyond that, you have to ohm it with a meter to see resistance on the individual inj and glow plugs. I am not the best with ae so someone else with more info can elaborate.
You did not mention the mileage but sounds like bad inj or bad oil. You can pull the v/c and check the oil discharge from the inj spouts when cold to see. I bet you have a more than 2 inj not working properly when cold.
Old 07-21-2013, 11:23 AM
ScottInTexas
Thanks for your help. I have to set this aside and find another problem. All of a sudden the truck doesn't want to go beyond 65 MPH at 2000 RPM. It sounds like it should shift, but wont. Overdrive switch works because when you turn it off the RPMs go way up. But something is not right. If this wasn't a public forum I would be writing all sorts of bad words right now! All I can say publicly is "Darn it!"
Old 07-21-2013, 11:53 AM
Tugly's Avatar
Tugly
Tugly is offline
Allowing AE to pull codes when you first hook up may give you your first clue.
This sounds like a classic ICP issue. At wide open throttle (in gear) you should see 2800 PSI ICP with 40%IPR. If you see 2800 PSI ICP with a significantly lower IPR, your ICP is lying to the PCM (reading high). It's worth checking.
If my memory is hanging in there, I believe the buzz test (Key On, Engine Off) will tell you if you have any open connections on the UVCH... as well as which ones they are.
KOEO may help as well.
Old 07-21-2013, 02:04 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Shake-N-Bake is offline
Sounds like a possible fuel supply issue.
Old 07-21-2013, 09:03 PM
Pitcrw6's Avatar
Pitcrw6
Pitcrw6 is offline
Subscribed
pstrokemike97
03-15-2019 09:52 AM
Boost240sx
13
10-13-2016 12:32 PM
luny1
12-24-2012 09:57 AM
maxtegroom
09-19-2011 10:46 AM
paulgc
10-10-2006 05:51 PM
Quick Reply: Using AE to check UV wiring harness
