6.2L V8 Discuss the 6.2L V8
Bilstein rear shock report
Old 07-18-2013, 03:38 PM
ATP Pilot's Avatar
ATP Pilot
ATP Pilot is offline
Installed some Bilstein 4600 shocks on my 2wd F250. Ride seems to be a little better unloaded. I was getting a lot of hop over bumps, even with the rears at 60 psi. Install was easy, but I had an impact wrench, it would be tough with out one.
Boot looks funny in the picture because it was taken from the ground looking up the shock.
Old 07-18-2013, 03:58 PM
2000silverbullet's Avatar
2000silverbullet
2000silverbullet is offline
After reading RZAR's thread about his Bilstein experience, keep an eye on those puppies!
https://www.ford-trucks.com/forums/1...k-failure.html
Old 07-18-2013, 06:37 PM
rvpuller's Avatar
rvpuller
rvpuller is offline
I can honestly say that I'm not overly impressed with the shocks on my truck and after our first good pull next week I may replace them but I will go with Monroe Gas Magnums like I had on my last truck.
2000silverbullet I have never seen a shock overheat and fail like that and I have put a lot of miles on trucks with slide in campers and 5th wheels on some not so great roads.
Denny
Old 07-18-2013, 08:53 PM
2000silverbullet
I've never seen it either but the fact that Bilstein didn't stand behind their product doesn't sit well with me...
Old 07-24-2013, 11:15 PM
eberlestock's Avatar
eberlestock
eberlestock is offline
I run the bilstien 5100s and they are a good upgrade from a set of ranchos.
Old 01-11-2014, 07:42 PM
Big_Daddy_O's Avatar
Big_Daddy_O
Big_Daddy_O is offline
Well after just installing a set of Bilstein shocks I can say for right now what a difference than the stock shocks that were on the truck. With only 25,000 miles on it the stock ones are junk. I pushed them in to see how they reacted and they never even came back out. Cant wait to haul the camper and see how they work. Used to bounce all around on the old shocks.
Old 01-12-2014, 12:08 PM
JimRay's Avatar
JimRay
JimRay is offline
I may be wrong, but most shocks don't have rebound springs. They dampen the suspension springs. Big Daddy, did you have the Rancho shocks that came with the FX4 pkg? I have a 2014 SD with the FX4 pkg and seems to ride stiffer (rougher) than the demo I drove.
Old 01-12-2014, 12:59 PM
rvpuller's Avatar
rvpuller
rvpuller is offline
Originally Posted by JimRay
I may be wrong, but most shocks don't have rebound springs. They dampen the suspension springs. Big Daddy, did you have the Rancho shocks that came with the FX4 pkg? I have a 2013 SD with the FX4 pkg and seems to ride stiffer (rougher) than the demo I drove.
Most shocks have a gas charge that makes them rebound or extend. My truck only has 6600 miles on it but by the time it hits 12K it will have Monroe Gas Magnums on it, factory shocks just don't hold up.
Denny
Old 01-12-2014, 02:33 PM
JimRay's Avatar
JimRay
JimRay is offline
By "factory", do you mean the Rancho shocks on the FX4 pkg?
Old 01-12-2014, 05:12 PM
Big_Daddy_O
No they were not Rancho shocks. Ford brand I guess? They were all black. I plan on doing the front next. I have read a lot about the Rancho ones also that come on the FX4 package. I like the stiffer ride. In my opinion that's the way a heavy duty truck should ride not like a car. There was also a video from someone on here that I saw on the Rancho shocks that come on the FX4 package, but cant remember where I saw it.
Old 01-12-2014, 06:24 PM
Gary2Fords's Avatar
Gary2Fords
Gary2Fords is offline
There seems to be a common misconception that the "Rancho" shocks on the FX4 are poor quality or defective because they don't rebound when compressed by hand. They are hydraulic shocks and work differently than gas shocks like the Bilstiens. Hydraulic shocks don't rebound when you compress them. It's the pressure in a gas shock that makes it rebound.
That being said, I think the Bilsteins, or other gas shocks are better on these trucks. I changed to Bilstein 4600's on my 2012 FX4 and found that the truck seems more sure footed with less rear wheel hop. I don't think the ride improved at all though.
On another note, I took a 10,000 mile trip with my truck camper in the bed this summer. On all kinds of roads, the Bilstens worked great and suffered no ill effects or overheating.
Old 01-13-2014, 06:37 AM
goingnorth's Avatar
goingnorth
goingnorth is offline
I changed to bilsteins with maybee 500 miles on truck and 3 of the factory shocks had some slow rebound and 1 had none.
Old 03-02-2014, 09:40 AM
Retread65's Avatar
Retread65
Retread65 is offline
After my 94 yr old mother made a comment about my truck riding rougher than it did when new, I replaced the FX4 Ford factory Rancho shocks with Bilstein 4600 series shocks yesterday. The difference in handling control and smoothness perception was immediate. Much better control when trying to jump potholes ! Truck has 20,300 miles on it.
Old 04-13-2014, 07:20 PM
Rubiconrod's Avatar
Rubiconrod
Rubiconrod is offline
Installed bilstein 4600's on all four corners this afternoon. Noticeable difference. Worth the money to me. Going camping this weekend so we will see how they hold up.
GoldCo
09-04-2017 11:38 AM
Oilfield Trash
07-28-2016 08:41 AM
Gary Lewis
40
02-08-2013 09:17 AM
EXv10
10-27-2012 07:03 PM
00Dave
07-12-2008 06:28 AM
Quick Reply: Bilstein rear shock report
