View Poll Results: black or gray icm
black
0%
gray
100.00%
Voters: 2. You may not vote on this poll
black or gray
Old 08-10-2013, 10:26 AM
grldben's Avatar
grldben
grldben is offline
black or gray
hey guys i have a question i have a 1991 f-150 4.9l would like to know which icm i should use black computer controlled or gray push start kinda cofused thanks in advance
Old 08-10-2013, 03:58 PM
rla2005's Avatar
rla2005
rla2005 is offline
Received 1,164 Likes on 919 Posts
No reason for a poll. A quick search on this forum will tell you that you need a gray colored push-start style ICM. Ford did not start using the black ICM/CCD style ignition until 1994.
Many part manuals, including Ford are wrong....you need a gray colored Push-Start ICM. No ifs, ands or buts.
Old 08-10-2013, 05:37 PM
Eddiec1564's Avatar
Eddiec1564
Eddiec1564 is offline
The black ICM(TFI module) will run with a older ECU but will not work properly as the black TFI does not control the dwell to the coil, it expects the ECU to do that. You will get hard starting ,engine pinging and misfires with the black TFI module.
Old 08-11-2013, 07:01 AM
grldben's Avatar
grldben
grldben is offline
Ok great thanks guys. Now to find the root of my problem
icrman
16
06-12-2022 07:56 PM
jgrohs54
01-21-2016 10:43 AM
perryau1996
10-03-2011 11:33 AM
tygarcia
1978 - 1996 Big Bronco
19
01-29-2010 08:00 PM
Quick Reply: black or gray
