1978 - 1996 Big Bronco
1995 Bronco stalls when put into drive
Old 06-13-2013, 03:13 PM
dweb4's Avatar
dweb4
dweb4 is offline
I have a 95 bronco, that until yesturday was running fine. I got in and put it into drive and then the engine just died. I put it back in neutral restarted and let it warm up. Put it back in drive and engine stalled again, engine will not run in drive. The fluid was a little low I added half a quart and still same result. I can put the truck in reverse and the truck runs like a dream but soon as I put it in drive again, stall. Any help would be appreciated. Thanks
Old 06-13-2013, 10:32 PM
Encho's Avatar
Encho
Encho is offline
The Southernmost Mod
Welcome to FTE dweb4! You're probably lacking way more ATF than the half qt. you put in. The ATF level has to be measured with the engine running at operating temp. while in Park, usually I would advice running around the block and driving around for a while before taking the measure but in your case that won't be possible. Once filled try moving the truck again, and remember checking the fluid at least once more later the same day, same procedure.
How did you measure the ATF level anyway?.
Old 06-13-2013, 11:55 PM
Torky2's Avatar
Torky2
Torky2 is offline
Just off of the top of my head, two thoughts.
Since it's OK in Reverse, that seems to say the IAC is OK.
1)Some electrical problem with the transmission range switch?
2)Engine torqueing on mounts causing an electrical or vacuum problem?
Of course the engine always turns the same way, CW as viewed from the front. For every action there is an equal and opposite reaction...
So when in Drive and foot on brake, the engine torques CCW (as viewed from the front) against the stopped driveshaft, since the trans output shaft would turn CW in all forward gears.
But when in Reverse, the driveshaft would turn CCW (as viewed from the front), so the engine would torque over in the CW direction... the opposite of when you are in Drive.
So, is there some electrical connection or vacuum connection that is opening up when the engine torques CCW? Maybe vac line to the MAP sensor, vac take-off to the brake booster, loose battery terminal, etc. etc.
Just some thoughts.
Old 06-14-2013, 12:05 AM
Encho's Avatar
Encho
Encho is offline
I just thought, what about a faulty MLPS? that would probably cause problems too.
Old 06-15-2013, 03:44 PM
dweb4's Avatar
dweb4
dweb4 is offline
Ok did a little work today and here is what I have now. Took truck out and it will drive again in reverse as well as 1st gear and once driving shift into second no problem I put into drive and truck will run but once I slow down in drive to under about 5mph the engine sputters and it goes into a stall. I checked the fluid it was ok, so I decided to change it anyway. Took pan off filter still attached to the trans, I put new filter, pan gasket and fluid in. Went back out same results. So I went and got a ford code reader and this is what I got:
Engine off codes: 157, 629
Engine on codes: 536, 538, 632
Please feel free to give me your comments and thoughts, if I can't solve it by tomorrow it's going to the shop.
Old 06-15-2013, 04:50 PM
greystreak92's Avatar
greystreak92
greystreak92 is offline
Code 157 - Indicates a mass-air sensor fault. Assuming yours is indeed a mass-air equipped model, that is the root of your stalling problems. Replacement is the best course as repair is not typically advisable.
Code 629 (during the KOEO test) - indicates that the transfer case was engaged in a 4WD gear (HI or LO) during the KOEO test.
Code 629 (during the KOER test) indicates that the TOT (Transmission Overall Temperature) sensor was out of range (too cold) to perform the test. OR that the TOT sensor indicated high voltage back the to the ECM (meaning the the external temperature was less than -40º F....highly unlikely unless you live that far north or south).
Code 536 - Indicates that the operator did not step on the brake pedal during the KOER test. (If you did, and this Code still shows up, check your brake light switch for proper operation).
Code 538 - Indicates the operator did not perform the "goose test" during the KOER. This is the dynamic response portion of the test. There is no other reason for this Code to manifest.
Code 632 - Indicates that the operator did not de-activate/re-activate the Overdrive cancel switch during the KOER test.
Old 06-15-2013, 06:06 PM
dweb4's Avatar
dweb4
dweb4 is offline
Ok went back and pulled the codes again, after noticing I was missing steps, here is what I got now.
KOEO codes
157, and 629
KOER
no codes
I'm hoping it is just the mass-air sensor...
Old 12-31-2016, 11:18 AM
Ddanos80's Avatar
Ddanos80
Ddanos80 is offline
Problem fixed?
KOEO codes
157, and 629
KOER
no codes
did you ever get the problem fixed??? Mine started doing the same thing last night.
Old 12-31-2016, 11:19 AM
Ddanos80's Avatar
Ddanos80
Ddanos80 is offline
Problem fixed?
Did you ever figure out the issue??? My started doing the same thing last night.
Old 06-16-2018, 12:09 PM
rvarc's Avatar
rvarc
rvarc is offline
KOEO codes
157, and 629
KOER
no codes
Hi, did you ever find the problem
Old 06-20-2018, 04:45 PM
rla2005's Avatar
rla2005
rla2005 is online now
Received 1,172 Likes on 926 Posts
The OP has not been on this forum since 06-30-2013 11:56 AM
Best bet is to start your own new thread for whatever issue you are having.
edit: NVM...you already did https://www.ford-trucks.com/forums/1...-stalling.html
Old 06-20-2018, 07:11 PM
rvarc's Avatar
rvarc
rvarc is offline
Yes, thanks. Waiting on the part and will update.
Old 08-24-2019, 05:22 PM
Missy Steele's Avatar
Missy Steele
Missy Steele is offline
95 bronco did the same way 4 Yea ago. I have been driving it ever since like a straightshift on the column.
Try starting out in 1st and as your speed changes you gear up or down accordingly. I can't figure out what's wrong with mine but at least I can drive it if I have to like this. Also my overdrive starts blinking and it will really act a fool. idk I have tried several things with no results. Last thing I tried was changing speed sensors with no luck. Good luck and hope you get a fixed answer so I can possibly get mine fixed.
animal2b
06-13-2014 10:36 PM
alaskan6667
1999 to 2016 Super Duty
25
12-31-2012 06:35 AM
f100help
08-30-2010 08:08 PM
jsutton
04-04-2008 09:37 AM
VWandSTUDEBAKER
Bronco II
47
10-23-2006 11:11 PM
Quick Reply: 1995 Bronco stalls when put into drive
