Still having trouble removing my clarion radio from my 1994 Ford F150.
Here is what i've done so far. I took the trim piece off and i see two clips like this on each side. What should i do?
This is what i see:
http://img547.imageshack.us/img547/8836/img0502t.jpg
This is what i see:
Found this after some google searching...hope it helps
Press the detachable face release button on the face of the stereo and pull off the face using your hands. Place it to the side where it can't get damaged.
Hold the bottom of the trim piece that goes around the perimeter of the stereo and push it up to remove it from the stereo body. Place it to the side where it can't get damaged.
Place the Clarion hook plates into the sides of the stereo on the vertical edges, about the middle of the deck, until they click into place. This will free the stereo from the cage and allow you to pull it out.
Pull the stereo out by the hooks and remove it from the cage. Once the stereo is out of the cage completely, unplug the antenna lead and the wiring harness from the back of the stereo.
If you don't have them...I highly suggest you get the keys
http://compare.ebay.com/like/330588036004?var=lv<yp=AllFixedPriceItemTypes&var=sbar
on
You need to slip something between the mounting cage and the radio about 2" long, 3/8 wide and 1/16" thick to release it.There are 2 clips, one on each side, right in the middle. The radio will slide out then.
EDIT: I typed that post before the other responses, then forgot to hit submit, so it may not be any help.
molliemcguire
06-06-2008 03:58 PM
