Still having trouble removing my clarion radio from my 1994 Ford F150.
Old 06-08-2013, 04:12 PM
Loganc95's Avatar
Loganc95
Loganc95 is offline
Here is what i've done so far. I took the trim piece off and i see two clips like this on each side. What should i do?
This is what i see:
http://img547.imageshack.us/img547/8836/img0502t.jpg
Old 06-08-2013, 04:29 PM
Fastback460's Avatar
Fastback460
Fastback460 is offline
Found this after some google searching...hope it helps
Press the detachable face release button on the face of the stereo and pull off the face using your hands. Place it to the side where it can't get damaged.
Hold the bottom of the trim piece that goes around the perimeter of the stereo and push it up to remove it from the stereo body. Place it to the side where it can't get damaged.
Place the Clarion hook plates into the sides of the stereo on the vertical edges, about the middle of the deck, until they click into place. This will free the stereo from the cage and allow you to pull it out.
Pull the stereo out by the hooks and remove it from the cage. Once the stereo is out of the cage completely, unplug the antenna lead and the wiring harness from the back of the stereo.
If you don't have them...I highly suggest you get the keys
http://compare.ebay.com/like/330588036004?var=lv&ltyp=AllFixedPriceItemTypes&var=sbar
Old 06-08-2013, 04:37 PM
Loganc95's Avatar
Loganc95
Loganc95 is offline
Thanks ! this helps alot !!
Old 06-08-2013, 04:45 PM
cjcocn's Avatar
cjcocn
cjcocn is offline
Those are what I was talking about - I was unsure of the correct terminology.
Glad you got the info you were looking for.
Old 06-08-2013, 05:44 PM
bashby's Avatar
bashby
bashby is offline
You need to slip something between the mounting cage and the radio about 2" long, 3/8 wide and 1/16" thick to release it.There are 2 clips, one on each side, right in the middle. The radio will slide out then.
EDIT: I typed that post before the other responses, then forgot to hit submit, so it may not be any help.
Big-Red-Lariat
2009 - 2014 F150
05-08-2013 12:08 AM
molliemcguire
06-06-2008 03:58 PM
sled_ers_rus
1997 - 2003 F150
05-03-2005 12:51 PM
AL73
2004 - 2008 F150
08-25-2004 08:51 PM
chaser
1978 - 1996 Big Bronco
01-05-2002 05:34 PM
Quick Reply: Still having trouble removing my clarion radio from my 1994 Ford F150.
