6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Replacing oil cooler on 2008 F250 6.4
Old 08-12-2013, 05:20 PM
jdshepa's Avatar
jdshepa
jdshepa is offline
Same problem... I think
2009 6.4L 164k miles
Hey guys, I learned today that I have the same code. Been seeing the wrench for awhile .... bought the truck used.. from a Ford Dealer.. with a 154k miles. Buying from a Ford dealer, I figured they would have run it through the ringer as far as service and fixing known issues. Had it about a month when I learned that I had to replace the radiator... been problem after problem... the latest is the wrench. Took it to my local dealer last week, they said the only thing they could find was bad exhaust temp sensors, both of them....
Two days later, the wrench is back. Today, I took it to a different dealer, while the wrench was lit, left it running until they could hook up and tell me what the code was. ECT was about 188 and EOT was about 230. The mechanic said that code usually means oil cooler replacement in his experience. Remove cab, etc. etc. He said there could be trash in it...
Any way clean it before having to replace to see if it works? And how much did it cost to have it replaced??
Thanks for all the info
J
  #32
Old 08-12-2013, 05:26 PM
senix's Avatar
senix
senix is online now
Received 1,459 Likes on 1,041 Posts
do a coolant flush is about all you can do. I got one when my coolant needed replaced for about 160 bucks or so.
Check the thermostats maybe they need attention. Much cheaper to have a look at them.
  #33
Old 08-12-2013, 05:46 PM
jdshepa's Avatar
jdshepa
jdshepa is offline
Thanks, I had them do a complete coolant flush when they put the new radiator on a few months ago, I think. I'll have them check the Tstat's first.
Thanks
  #34
Old 08-12-2013, 05:49 PM
SCR6.4's Avatar
SCR6.4
SCR6.4 is offline
My problem ended up being one bad T stat ( replaced both) After certified flush with VC 8 and 9, etc., the code came back. Replaced the oil cooler. Now temp deltas are fine. Cost of t stats; flush and oil cooler was slightly south of $3,000 at Ford dealer.
BTW, before repair, my ECT was in the 195 range and EOT was 230 under no loads and 78 degree temp.
  #35
Old 08-12-2013, 07:03 PM
CKetchum's Avatar
CKetchum
CKetchum is offline
I had to replace my oil cooler a while back due to having Ford Gold and Green Universal antifreeze mixed, contaminating the coolant causing gelling in the oil cooler.
One thing to think about if you have to replace the oil cooler is there is a lot of stuff that comes off that you can have replaced for periodic maintenance at the same time and Ford will only charge you for the parts since they are removing them anyway. I had both my belts replaced, both thermostats, fuel cooler, etc. At least I didn't incure any more labor costs...in then end it's the labor costs that adds up.
  #36
Old 08-13-2013, 09:38 AM
SANDDEMON08's Avatar
SANDDEMON08
SANDDEMON08 is offline
Originally Posted by jakedsnk
Hey, first post here. I have an 08 with a Mini Maxx tuner and am seeing 195-205 ECT and up to 240 EOT. I am not getting any codes or the wrench. Has anyone seen this happen before?
Thanks,
Jake
Welcome to FTE, 240 EOT is the limit I would run the truck before pulling over and letting it cool, you are probably not getting any codes because you have a tuner. I’m not over familiar with the Mini Max tuners but that is based on how other tuners I have seen. Are you seeing these temps under load or are these being seen daily driving? My EOT and ECT run within 2 degrees of each other all the time unless I am towing then I can see about a EOT 10-15 degree difference higher then ECT with a sustained 1250-1300 EGT under a heavy load, which IMO is not bad considering the pistons are oil cooled.
  #37
Old 08-13-2013, 08:59 PM
jdshepa's Avatar
jdshepa
jdshepa is offline
What do I need to buy to monitor the ECT and EOT? I do not know exactly what it running, and I just read (above) that 240 is the max. I do not pull any heavy loads, but I do go on 3 hour highway rides frequently.
Thanks guys!
  #38
Old 08-14-2013, 08:21 AM
GSchretter's Avatar
GSchretter
GSchretter is offline
Thanks guys!
I use the EDGE CTS. Perfect size.
  #39
Old 01-28-2014, 02:07 PM
dndmicks79gx's Avatar
dndmicks79gx
dndmicks79gx is offline
Just dropped My f250 6.4 back off at ford yesterday. I got the P code back around thanks giving pulling my camper and took to ford when i got home and of coarse tried to give me the run around but it was under warranty but of coarse they wanted to charge me for something so they did a coolant flush then replace the egr valve but it sure didnt look new. now this past weekend pulling the camper again the same code lucky i was 15 miles from home so back to ford and now they say its the oil cooler blockage must of been from there coolant flush? so now cab off and replace. thank good warranty hasnt expired yet 15000 more miles
  #40
Old 09-11-2015, 08:16 PM
Motofreakk's Avatar
Motofreakk
Motofreakk is offline
High oil temp/delta
Originally Posted by parkland
I thought my oil cooler was bad, but the coolant had an air lock somewhere or something, and when it finally got figured out, the oil cooler numbers are back to normal.
How did you fix the air lock??
Also a question for all...
By "oil cooler" do you guys mean the cooler in front of the radiator or the thing sitting on top of the motor???
Blurr4x270
12-14-2015 10:52 PM
mudfuel06
08-08-2014 12:04 PM
jl4407
08-13-2013 10:45 PM
GeneLaw1
12-26-2012 11:21 AM
Headviking
10-21-2009 07:27 AM
Quick Reply: Replacing oil cooler on 2008 F250 6.4
