BulletProof
Old Dec 24, 2012 | 11:57 AM
GeneLaw1's Avatar
GeneLaw1
BulletProof
Good day gents,
I am planning to do a "bulletproof" at the top of the year. HG's, ARP studs, EGR delete, all that. I had a question referencing the Oil cooler...is that something that needs to be replaced? The mechanic doing the bulletproofing recommended based on how hard it is to get to if it goes bad later. I was thinking that it wont go bad if its flushed and all while doing the rebuild.
What are you alls opinions?
Old Dec 24, 2012 | 12:15 PM
Misky6.0's Avatar
Misky6.0
Originally Posted by GeneLaw1
Good day gents,
Sometimes flushing actually seems to stir up the cra* and clog the oil cooler up.
Since you are planning to do so much, i would flush first, then replace it, refill with new coolant. Some use an extended life to eliminate the silicates which *may* be part of the clogging.
Old Dec 24, 2012 | 12:55 PM
MC5C's Avatar
MC5C
Since the whole point of a "bulletproof" is to protect against things that happen when the oil cooler fails or gets clogged, it seems that doing the "bulletproof" and not doing the oil cooler would be a bit of a waste of money. What issues are you having to make you spend that kind of cash if not the oil cooler? Do you plan to tune the truck up towards 500 hp or something?
Brian
Old Dec 24, 2012 | 01:02 PM
GeneLaw1's Avatar
GeneLaw1
Brian
I may have a blown head gasket (have symptoms), although I have not done a full check to verify. I do not plan to tune it to that many horses, but I plan to tune it, and do not want to be worried about the HG issue. As of now, the oil cooler is keeping the oil temps well within spec!
Old Dec 24, 2012 | 01:15 PM
69cj's Avatar
69cj
If I was to open up my engine, esp. if I'm paying for someone elses labor, I definitely would install a new oil cooler. It's cheap compared to the labor to get to it.
Old Dec 24, 2012 | 01:20 PM
GeneLaw1's Avatar
GeneLaw1
That sounds like good rationale to me!
Old Dec 24, 2012 | 01:29 PM
GeneLaw1's Avatar
GeneLaw1
Anything else I consider replacing while he's in there...I know he mentioned he would be putting in 6.4 Banjo Bolts as well...
Old Dec 24, 2012 | 01:42 PM
69cj's Avatar
69cj
Fuel press. blue spring upgrade and stand pipe dummy plug upgrade if needed. STC fitting if old style is present. Make sure he uses OEM head gaskets.
Old Dec 24, 2012 | 01:59 PM
kidoo's Avatar
kidoo
I would defenitly flush and backflush the cooling system to death before I replace the oil cooler, plugs removed from the engine and lower radiator hose disconnected. And I would flush and backflush the heater rad independently from the in and out hose.
I would suggest you drop the coolant in a pail from the lower rad hose just to see if there is any crap in there. If there is some flakes, clean that radiator before crap get in the oil cooler. It happened to me.
Old Dec 24, 2012 | 02:06 PM
69cj's Avatar
69cj
This would also be a good time to install a coolant filter.
Old Dec 24, 2012 | 11:50 PM
daddykitty's Avatar
daddykitty
I would do that before you tear it apart....give the coolant filter a chance to get a head start on the whole process. you would be amazed at the junk you will find
Old Dec 26, 2012 | 09:40 AM
GeneLaw1's Avatar
GeneLaw1
Thanks for the responses! I have a Coolant filter installed already, installed it a back in April actually.
Also, due to other issues I had I have done the Blue spring (last December, had a leak in that bowl) and the Dummy plugs and SCT (had to replace the HPOP back in May).
Old Dec 26, 2012 | 10:08 AM
MisterCMK's Avatar
MisterCMK
Gene, you are gonna have to turn up the tune once you stud it. Mine ran a 14.4 with a toolbox and a full tank of fuel. Go baby go!.
Old Dec 26, 2012 | 10:57 AM
GeneLaw1's Avatar
GeneLaw1
I mistyped...I am not tuned yet...earlier I meant to say I had the new "STC" on the HPOP. lol
Old Dec 26, 2012 | 11:17 AM
_Me2_'s Avatar
_Me2_
All good advice so far. The only thing I would add is to regularly check the FICM if you don't do so already. It's nice to have all of the problem areas fixed so you don't have to worry about the truck.
