brake conversion on a 57 f100
Old 05-15-2013, 07:43 AM
rgoodell's Avatar
rgoodell
rgoodell is offline
disc brake conversion using 5 on 5.5 rotors, what do I need ?
Old 05-15-2013, 11:25 AM
a4t1rat's Avatar
a4t1rat
a4t1rat is offline
Rotors
Calipers
Caliper Mounts
Bearings, Races and Seals
Master Cylinder
Proportioning Valve
Brakes Lines
Brake hoses
Search the forms there is a good write up on here, just forget where. Pretty easy I have done many of them.
Old 05-16-2013, 05:46 PM
Walston's Avatar
Walston
Walston is offline
I got my kit from ECI.
Old 05-17-2013, 03:50 PM
vntgtrk's Avatar
vntgtrk
vntgtrk is offline
How well did everything bolt up? Any problems? I'm considering their stuff down the line
Old 05-17-2013, 06:53 PM
Walston's Avatar
Walston
Walston is offline
They worked very well and bolted up easy. Some pictures in my gallery. Here is one.
https://www.ford-trucks.com/user_gal...=73494&width=0
Old 05-17-2013, 06:58 PM
vntgtrk's Avatar
vntgtrk
vntgtrk is offline
Clean look, almost like a factory install. OP, most of these kits you'll see on the interwebz are available either complete or stripped down. With the stripped down kits you use salvage yard ford truck rotors/hubs and GM big car calipers from, IIRC, late '70's to early '80's. I plan on running drums to start, but I have a pair of the proper rotors. They've been turned already
Old 05-17-2013, 07:22 PM
Walston's Avatar
Walston
Walston is offline
It has been a few years, but if I remember correctly you remove all the old stuff and reverse the pin that holds the king pin in place. I replaced the kin pins at the same time. Bolt the bracket on. That is the most important part. The calipers and are late 70's GM, the rotor are late off an f150. You have to change the bearing race and the bearing to fit the old spindles. Need a hydraulic hose, need a new master cylinder, I use one from a 1973 F100 that had disc and drum. It was cheap and didn't need a proportioning valve. I also used the booster and mounting bracket from the 73. The kit is easier, but after the bracket, the rest can come from a salvage yard.
Old 05-17-2013, 09:30 PM
deyomatic's Avatar
deyomatic
deyomatic is offline
Be sure to read this "How-To." Had I read it before I did mine, it would have been 1000x easier! Good photos, too.
Installation of Manual or Power Brakes Disc Brakes in a 1957 - 1964 F100 .: Articles
robbm
05-10-2011 08:15 AM
stangguy61
03-24-2007 02:39 PM
allenl
01-12-2006 01:53 PM
kwilson
09-19-2002 11:33 AM
enduringexplorer
07-26-2002 11:54 AM
Quick Reply: brake conversion on a 57 f100
