68' 429 ThunderJet
Old 05-05-2013, 08:45 PM
angrymade's Avatar
angrymade
angrymade is offline
68' 429 ThunderJet
Hey all,
I've got a 68' 429 ThunderJet in my LWB 66' F100. It's pretty much stock aside of carb, intake, dist., and ignition. I'd really like to throw a little hotter cam. I've been looking at a Comp Cams Thumpr cam and lifters kit with new valve springs, etc... Lift .506/.493
My curiosity is running this cam with my essentially stock heads. I do not plan on doing any kind of racing. I rarely get over 2500rpm. I would just like that nice lopey idle.
Any help would be great.
Thank you,
Jesse
Old 05-05-2013, 09:34 PM
ManfredVonRichtofen's Avatar
ManfredVonRichtofen
ManfredVonRichtofen is offline
What heads do you have on it? DOVE? C9VE? or what?
Old 05-05-2013, 10:50 PM
devconk's Avatar
devconk
devconk is offline
I have a mild cam on my '68 429 with the DOVE heads and it runs fine.
Old 05-06-2013, 09:04 PM
F-250 WARHORSE's Avatar
F-250 WARHORSE
F-250 WARHORSE is offline
That thing should have monster torque on the bottom end with a mild cam and the high compression. I will say this: Get new valve springs atleast, and make sure you have a new timing set and new lifters, but that cam at basically 500 lift is going to be pretty mild, my 545 has a 274/286 560 something lift and it lopes, snorts, and flat rips.
Old 05-20-2013, 01:27 PM
angrymade's Avatar
angrymade
Hey guys, it's been a bit since I've been able to get back to this. The heads
have what looks to be " C8VE-E " for a casting number. The 8 could be a 6 as I didn't have much light.
Anyone know much about these heads?
Old 05-20-2013, 02:56 PM
ManfredVonRichtofen
They're not smoggy like the D2 and D3 heads.
Old 05-20-2013, 07:00 PM
bigdan1979f-250's Avatar
bigdan1979f-250
bigdan1979f-250 is offline
Angry, you have c8 head castings. To my knowledge there are no c6 casting heads. The heads are good, as they have the 75 cc chambers and the motor has a high compression ratio (around 11:1 I think). I would say for what you want the cam you selected would be a good choice for your application. I think your valve springs would be borderline on the lift as far as needing to change them out, but if you have the money to do it, I would go ahead and do it. When in doubt, ask the cam mfg if stock springs will work with their cam
Old 06-08-2013, 08:54 PM
fordparts429's Avatar
fordparts429
fordparts429 is offline
429 SCORE!!!!!!
Cool!!! Sorry, posted in the wrong thread.
ozblitz
02-03-2010 02:29 PM
bigblueovalman
12-31-2007 02:18 PM
Boss Machine
12-01-2006 10:35 PM
BigJake86
05-30-2003 11:41 PM
Ravin
11-26-2002 11:18 PM
Quick Reply: 68' 429 ThunderJet
