Cam shafts
Old Nov 24, 2002 | 05:42 PM
Ravin's Avatar
Ravin
Cam shafts
CAn cams be taken out and installed without tearing apart an engine?
Also If you can take out the existing cam and replace it a more agressive cam, do you need to worry about replacing pistons, heads or anything?
I want to thank all that respond to questions i have. I am a Fairly new car guy, and enjoying have some where to look for answer.
Thanks Jamison
Old Nov 24, 2002 | 06:33 PM
Franklin2's Avatar
Franklin2
Cam shafts
No. The whole front of the engine has to come off. The intake manifold has to come off. You have to take the radiator out, and still you may not have enough room sometimes to get it out. Really aggressive cams need new valve springs, and piston to valve clearance checking. Thecam manufacturer can give guidance on this.
Old Nov 26, 2002 | 07:56 PM
StangMan's Avatar
StangMan
Cam shafts
It makes it a whole lot easier to just pull the motor out and do it then. It also gives you the chance to freshen up your heads with new springs, which you'll need if you want an 'aggressive' cam. I think stock springs are rated to .5" lift or something, but if you've got a number of miles on the motor already it might not be a bad idea to go through the heads anyway.
So, what's an 'aggressive' cam?
TFS Stage III: Duration @ .05" Lift w/ 1.6
int / exh int / exh
236* 248* .574" .595"
Remember that an aggressive cam such as this will be wasteful on your mostly stock motor, and will in fact destroy your truck's driveability. A CompCam may be more suited for daily driving and low-end torque.
CCA-35-231-3: 206* / 214* .448" / .483"
Good luck,
Ben
Old Nov 26, 2002 | 11:18 PM
jrocco's Avatar
jrocco
Post Cam shafts
jack orchard
Jul 11, 2017 12:31 PM
rpatrick
Jun 16, 2011 08:06 AM
ErnieX
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
May 2, 2007 01:08 PM
luvinfords
Apr 21, 2005 05:41 PM
Donate52
Dec 22, 2002 02:32 PM
