How to disconnect t.case shift linkage?
Old 05-04-2013, 05:07 PM
Nothing Special's Avatar
Nothing Special
Nothing Special is offline
I'm trying to remove my t.case ('97 F-250HD, 44-07 t.case, E4OD trans) and I'm not sure how to disconnect the shift linkage. Here's a picture of the linkage.
It looks like there's a plastic or rubber piece (the yellow arrow) that was slid over a pin on the shift arm (the green arrow), and then the shift link (the red arrow) was snapped over the plastic piece.
It looks like the only way to disconnect the link is to pull / pry it off the plastic piece. I'm pretty sure if I do that I'll wreck the plastic piece. I have pryed it fairly hard without popping it off, and I don't want to pull any harder until I have a better idea of what I'm doing.
Old 05-04-2013, 05:31 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
A pair of channel locks.
Grab the backside of the linkage with one jaw and push on the pin with the other jaw. USE LUBE!! the plastic bushing SHOULD stay on the pin
Old 05-05-2013, 09:06 PM
Nothing Special
Thanks Brad. It didn't go quite according to Hoyle, but I did get it off. In case anyone sees this later and wants to know how it turned out...
I couldn't get at the t.case end of the linkage with a channel lock, but getting the other end (at the shift lever) would work too, and I was able to get at that end. The 12" channel lock didn't give me enough force to get that end off, but it did shift it out far enough for me to get a 10" vice grip on it. That popped it loose, but the plastic piece came off with the link rather than staying on the pin. No problem as it popped back over the pin fine when I needed to reinstall it. So all's good.
The following users liked this post:
Old 05-01-2022, 03:07 PM
Glide89's Avatar
Glide89
Glide89 is offline
6th Gear
I appreciate it, I am down stairs in a moment to give this a try.
Old 08-19-2022, 09:39 AM
dremtofford's Avatar
dremtofford
dremtofford is offline
can you buy the plastic piece at the dealer?
Old 08-19-2022, 10:53 AM
SFaulken's Avatar
SFaulken
SFaulken is offline
You can get replacement bushings at any FLAPS, or Ford still, AFAIK.
kr98664
10-01-2020 06:28 AM
Turx
08-05-2018 05:55 PM
TheEscape
Escape & Escape Hybrid
09-08-2011 01:31 AM
410 Highboy
07-25-2011 08:12 PM
greystreak92
1978 - 1996 Big Bronco
11-05-2007 10:12 PM
Quick Reply: How to disconnect t.case shift linkage?
