shift lever removal
Old Jul 25, 2011 | 11:00 AM
410 Highboy's Avatar
410 Highboy
shift lever removal
I have to replace the shift collar . What is the best way to remove the pin that holds the lever on ?
Old Jul 25, 2011 | 11:21 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Drift punch works for all I've come across.
Old Jul 25, 2011 | 02:09 PM
410 Highboy
A drift punch is not working . I have several hours in using a drift punch. Looking for other options >
Old Jul 25, 2011 | 05:09 PM
410 Highboy
My mistake . The shift collar has an inner ring as well as the painted exterior . It looked like they were two seperate pieces . I was doing my best to avoid banging up the exterior surface . It looks like the next thing I will have to worry about is splicing the nine wires that I will have to cut to get the old collar off and the new back on .
Old Jul 25, 2011 | 06:31 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
The pins on the connector to wiring harness are removable allowing you to replace turn signal switch without cutting and splicing. At least on the same era vehicles I work on. It's probably a half moon shaped connector if I'm right. Think I have an old one I can post a pic and tell you how to do it.
Old Jul 25, 2011 | 07:15 PM
410 Highboy
they look soldered and rivited to me ,but this is new territory to me . Anything helps that will get it put back together right .I don't see any pins ?
Old Jul 25, 2011 | 08:12 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
The wires would run down thru inside of column and have a plug together connector under the dash. Actually a crescent shape, older years would have one or two square shaped connectors. The ends will come out of connector intact after releasing a small keeper and whole switch and wires pull out of column. Reinstall is just as simple. Run wires back thru column and push pins back in connector. No splices needed.
Shadowrider123
Apr 19, 2015 09:57 AM
vanwashe
Feb 28, 2012 09:09 AM
phimufreddy
Dec 9, 2006 11:58 AM
rokford
Apr 16, 2006 10:04 PM
Ron Crawford
1978 - 1996 Big Bronco
Dec 16, 2003 11:30 AM
