83 F100 column shift question
My 3 on the tree is poor, but still shifts. I think it's in good shape except for the collar and maybe parts of the column. The collar can slide up and down the column an inch or so, and I thought they just rotated, the shift handle did the movement. I looked at it and it seems the column cover from the dash to the collar is homemade or cheap aftermarket. It has a split in it that looks like it was made that way.
Does anyone have one of these for comparison?
I also have a Hurst floor shifter but want to save the column shifter if I can. The previous owner didn't drive the pin through the lower hole in the collar, so it has damaged the top hole already. I tried to coax the pin through but it doesn't want to budge. Does it need a press to get it through?
jplinville
07-27-2018 10:24 AM
Jason Ellison
11-19-2013 10:58 PM
ron65
01-06-2007 04:06 PM
