D60 Auto Locking Hubs
On the TTB axle stubs there are grooves around the outer stub that a snap ring rides in and holds in the three washers under it. The dana 60 stubs are different. They don't have the groove. Do you just assemble the auto locking hub the same and just leave out the snap ring or what?
Jacob I'm not sure about the 50's, but are you doing autos in the 60? If so, there is no outer snap ring that hold anything in. There is a half moon wheel key retainer with a notch that slides into the slot on the stub shaft. That's what keeps the spindle nut from spinning free.
On the 60 hubs I pulled apart there was no snap ring but no groove on the shaft either. I just put it back together the same minus the snap ring. Seems to work fine.
DanielT28
03-05-2013 07:29 PM
