460 headache
460 headache
Hello everyone. my 1988 460 is driving me crazy and i dont know what to do. awhile ago it would run and then stall out or rev down and die or just cut out for a second. i replaced the high pressure fuel pump, filter, pressure regulator, and after all that it, happend to be a bad relay. i also did a new distributor and ignition control module. that helped but its doing it again once it dies it takes awhile to start (between 5 minutes to 3 hours) i thought mabye it could be a bad "in tank" pump but could it also be electrical? i know its probably hard to diagnose but any help would be greatly appreciated and i can test or replace any suspected problems i just dont know where to start..
Forget trying to test intermittent ignition components, unless you catch them in a dead state they will likely test good.
Oreilly Auto Parts has NEW distributors, I'm not sure if there would be one available for your truck. Or you could replace the stator in the distributor you have.
Brnfree
25
09-14-2015 12:13 PM
1985.460
02-22-2013 10:37 PM
Bill Fournier
01-30-2012 12:01 AM
steve96I6
12-27-2011 10:27 AM
