460 headache
Old 03-03-2013, 07:55 PM
4rd1ton's Avatar
4rd1ton
4rd1ton is offline
460 headache
Hello everyone. my 1988 460 is driving me crazy and i dont know what to do. awhile ago it would run and then stall out or rev down and die or just cut out for a second. i replaced the high pressure fuel pump, filter, pressure regulator, and after all that it, happend to be a bad relay. i also did a new distributor and ignition control module. that helped but its doing it again once it dies it takes awhile to start (between 5 minutes to 3 hours) i thought mabye it could be a bad "in tank" pump but could it also be electrical? i know its probably hard to diagnose but any help would be greatly appreciated and i can test or replace any suspected problems i just dont know where to start..
Old 03-03-2013, 09:29 PM
88n94's Avatar
88n94
88n94 is offline
Where did you get your new distributor?
Old 03-04-2013, 01:58 PM
4rd1ton's Avatar
4rd1ton
4rd1ton is offline
its from NAPA its "remanufactured" so i guess its not totally new but i dont think it would be the problem..would it?
Old 03-04-2013, 02:40 PM
88n94's Avatar
88n94
88n94 is offline
YES. That would be the first thing on my suspect list. Rebuilt distributors have a terrible reputation. The first thing I would do is make sure you are losing spark when the engine quits and won't restart. If you find you are losing spark, you might try a new coil first. You already replaced the ignition module so you can rule that out.
Forget trying to test intermittent ignition components, unless you catch them in a dead state they will likely test good.
Oreilly Auto Parts has NEW distributors, I'm not sure if there would be one available for your truck. Or you could replace the stator in the distributor you have.
Old 03-04-2013, 03:34 PM
4rd1ton's Avatar
4rd1ton
4rd1ton is offline
ok what ill do is put a test plug on and watch it for awhile and if the spark quits as the motor dies then its gotta be eletrical. i just dont get how it can stip working and then fire right up after sitting for a little bit
Old 03-04-2013, 03:49 PM
88n94's Avatar
88n94
88n94 is offline
That's a pretty common problem around here. Has been since they quit using breaker points back in the 1970s.
Old 03-04-2013, 07:39 PM
4rd1ton's Avatar
4rd1ton
4rd1ton is offline
ok ill hope is something easy like that thanks alot!
Old 03-05-2013, 03:53 PM
4rd1ton's Avatar
4rd1ton
4rd1ton is offline
fired it up today and it ran no problem. soo i suposse its fixed, for now.
Brnfree
25
09-14-2015 12:13 PM
1985.460
02-22-2013 10:37 PM
Bill Fournier
01-30-2012 12:01 AM
steve96I6
12-27-2011 10:27 AM
Monty06
Bronco II
21
12-09-2004 11:41 PM
Quick Reply: 460 headache
