starting and stalling problem
Old Dec 20, 2011 | 01:08 AM
steve96I6's Avatar
steve96I6
i need some serious help i have a 96 f150 2wd 4.9 runs great except once and a while and getting more frequent will not start and will stall while driving sometimes start right up might not start for a while will try to start on starter fluid i have cleaned every electrical conection i can find replaced fuel filter and one of the fuel pumps plugs wires cap rotor ignition control modual replaced fuel pump relay put seafoam in the tank i would much rather get this done myself instead of taking to a shop and you guys on this site seem to know what your talking about i dont consider myself a mechanic but i think with a lil help from you guys on this site i can solve this problem
Old Dec 20, 2011 | 01:40 AM
88n94's Avatar
88n94
Three common things to fail. The coil, the stator in the distributor, and the ignition module. You have already replaced the ignition module.
That leaves the coil or the stator in the distributor. That's my guess.
Old Dec 20, 2011 | 11:11 AM
steve96I6's Avatar
steve96I6
i took off the coil had it tested they said it was good but i replaced it anyways since its not a constant problem could it still test good? and is there anyway to check the distributor to know if its bad? if i still have the problem i will replace it next
Old Dec 20, 2011 | 11:38 AM
88n94's Avatar
88n94
When stuff is intermittent like that, if you test it while in a running condition it will likely test good. Easiest to go trial and error with new replacement parts as long as they aren't too expensive, in my opinion.
You replaced the coil so that only leaves the stator in the distributor. I wouldn't recommend a rebuilt distributor as they have a terrible reputation. I would replace the stator in your present distributor.
Old Dec 20, 2011 | 04:32 PM
steve96I6's Avatar
steve96I6
thanks for the advice i put in a new distributor havent had issues yet but still too soon to tell will post again in a few days if it is solved
Old Dec 27, 2011 | 10:27 AM
steve96I6's Avatar
steve96I6
Thumbs up
thanks again for the advice no more problems just drove 600 miles to N.C. yesterday with out any troubles
tdel
Jan 8, 2013 11:56 PM
MrRogers
25
Jan 8, 2013 06:30 PM
steve87_gt
Bronco II
16
Apr 3, 2007 11:21 AM
scouterspokane
Aug 3, 2005 11:30 AM
wheelervc
Feb 27, 2005 11:23 AM
