cab to frame height/distance on 86 2x..
My cab mounts up front are both rotted and crushed, so I have no reference point to go from to make new ones and have the cab sit straight and level when done.
Measuring the rear the cab is 1/2'' lower on the drivers side, but that front mount is worse than the pass side.
Anyways, could somebody measure from the frame up to a reference point on the firewall, or even up to the cab floor from underneath?
I checked on my 94 bot that has poly mounts, and I remember the rear mounts were taller than factory, so I don't think that'll be much help.
Thanks for any help with this!!
Is the truck all apart? If the bed is still on it, I would use a string taped to the body line of the bed and run it up front as a reference. Just make sure the frame is level when you start doing this.
I don't have a measurement, and it would be hard to give one off a old truck, they are all a little squished by now.
rk-rex
12-31-2015 05:06 PM
JOSEPHU
02-21-2008 09:56 AM
