Frame
Old Nov 26, 2009 | 10:57 PM
jimford1's Avatar
jimford1
Frame
How/what can I do to see if my frame is bent of tweaked. I have a 68 shortbed. My body lines are off like 3/4 of an inch from bed to cab. Drivin me crazy. I thought it would be bent from how low my truck is. But these frames are tough!
Old Nov 27, 2009 | 09:57 AM
72-F100-4V's Avatar
72-F100-4V
Maybe your cab mounts are shot, I would check that first.
Otherwise find out the measuremets between the frame rails and start measuring the frame from front to back. Doesnt hurt to put in on a lift and give it a good once over.
Old Nov 27, 2009 | 12:15 PM
jimford1's Avatar
jimford1
Had it on the lift and everything looks great. The drop I beams are new. It was dropped the right way. I am going to check the cab mounts and just shuim everything up for next season if i have to. I will buy mounts also. Thanks man!!!
Old Nov 28, 2009 | 02:29 AM
72-F100-4V's Avatar
72-F100-4V
Im guessing the cab mounts only because my truck had a similar problem. The driver door was awful close to the fender. The cab mount looked alright, but once I pulled the cab it was a different story. Both front mounts were bad though they appeard good from the outside.
