high pressure oil line leak
Old 01-28-2013, 11:28 AM
Jmatthews's Avatar
Jmatthews
Jmatthews is offline
is a BAAAD MAN
I have a leak on the high pressure oil line going toward the passenger side. It looks like an oring got squished out. How do I fix this? do I need an oring or a special tool? It looks like I could unscrew it and put one in and put it back. Do I have to release some pressure or something first?
We are in a campground with SLOW wifi so it's hard to search.
Thanks
John
Old 01-28-2013, 11:36 AM
JOHN2001's Avatar
JOHN2001
JOHN2001 is offline
Is it the fitting going into the head or the line itself? The lines just simply push into the fitting on the head there's no oring there
Old 01-28-2013, 11:50 AM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
It's behind the hpop kinda under the fuel bowl, I guess I was unclear about that haha.
Old 01-28-2013, 12:01 PM
riverrat41's Avatar
riverrat41
riverrat41 is offline
There is an oring on both sides of the fittings.The fittings on the drivers side of the HPOP has a oring between the pump and the fitting.The fitting has a oring down under the connecting ring.Same application for the head fittings.
I would call Bob and get him to send you some if you do not have any.
Old 01-28-2013, 12:36 PM
JWAbercrombie's Avatar
JWAbercrombie
JWAbercrombie is offline
I just did hpop orings and fittings on mine. Look at diesel orings.com and they have a kit and a special tool to remove lines from fittings. Orings, tool and shipping was less than $60!! Not a hard job to do. I had mine start to finish done in less than an hour and that was taking my time.
Old 01-28-2013, 12:45 PM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
We are traveling now, would the dealer have those?
Old 01-28-2013, 12:53 PM
JWAbercrombie
Most dealers do. If its the oring between the fitting and the hpop you can remove it without the special tool. You'll need a stubby 19mm and some patience but it can be done. Be careful by doing this as not to damage the orings inside the fittings while spinning the fittings loose. Good luck!
Old 01-28-2013, 03:38 PM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
I got the orings from the dealer, came with loctite too. I don't know if i'll be able to get the thing off witout the quick connect off. Anyone try using a fuel line disconnect or something? Can't find one local.
Old 01-28-2013, 03:42 PM
riverrat41's Avatar
riverrat41
Sometimes you can get lucky with two flat head screwdrivers.Put the two screw drivers on hose side of the black plastic cover.Pry the hose while pulling on the hose.
Old 01-28-2013, 03:53 PM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
Thanks, I'll give it a whirl in the A.M.
Old 01-28-2013, 04:13 PM
JWAbercrombie
If your close to chattanooga,tn I can try to get you the tool I bought. You can google 'how to change hpop orings' and a guy made his own tool out of a cheap bicycle wrench. I think the opening was a 9/16, but the tool was very thin.
Old 01-29-2013, 07:19 AM
riverrat41's Avatar
riverrat41
You will need a pick to get the small oring out of the fitting.The oring rests under a plastic ring inside the fitting.Pay close attention when you remove the old one so you can see where it goes.The oring on the straight threaded fitting is self explanatory.It goes at the base of the fitting.
You can see the inner parts to the fitting.
HPOP Quick Disconnect Hose Fitting Repair Kit 1999 - 2003
Old 01-29-2013, 12:22 PM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
Got it fixed, ended up I had a very thin 1/2 wrench I ground down and sharpened it a bit. Worked like a charm.
Old 01-30-2013, 07:50 AM
riverrat41's Avatar
riverrat41
Good deal.Now that will be something you will always remember.
IBleedOvalBlue
21
06-10-2016 12:18 PM
CrazyCajun
07-18-2014 09:11 PM
glasseater
11-04-2013 09:41 PM
banjopicker66
12-25-2007 02:39 PM
Quick Reply: high pressure oil line leak
