Where do I start?
Where do I start?
On way RV show today, tow/haul starts flashing. On way home, still flashing, also have check engine light now too with a P0713 code. I noticed also the guage on dash for tranny temp isnt moved. I checked SGII and it said TFT was 8135 degress? It def wasnt shifting too well but i got it home and its in garage and i need some help on what this may be.
Classic Bad TFT Sensor
TRANNEY FLUID TEMP SENSOR CHANGE WITH PIC
https://www.ford-trucks.com/forums/1...placement.html
Click here for Change Pics^^^^^^^^^^^^^^^^^^^^^
When the PCM sees TFT That High it goes Into Limp Mode
Normaly change temp sender inspect harness and problem solved
Watch the TFT As truck Comes to Normal Temp If it Jumps its Tempeture around And Normaly pretty Drastic Jumps Way High to Low F* then about a 99.5% chance Sensor is BAD
DFO Diesel Filters Online Has Good Deals on Filters and they Have Mercon SP
They May even Have a New TFT Sensor IDK
I reaserched it some I need to change my TFT sender before Summer comes
Home - Diesel Filters,Additives,brake rotors, and brake pads for Chevy, Dodge and Ford Diesel Trucks
Here^^^^^^^^^
Just do a Spill N Fill on Fluid and Change that Filter and sender you will be good to Go
I wouldnt worrey about Flush
Should be able to reuse the Trans Pan Gasket too
Here^^^^^^^^^
6.0 Liter Turbo Diesel Transmission Filters - Ford 6.0 Liter Turbo Diesel Motorcraft External Transmission Filter - Diesel Filters,Additives,brake rotors, and brake pads for Chevy, Dodge and Ford Diesel Trucks
I use Valvoline atf with the lv/sp additive. just the back label. the hardest part is getting the inline filter apart. An impact gun works best.
Can you post a Link to this ATF and ADDitive????
Valvoline.com > Products > MaxLife > Automatic Transmission Fluid MaxLife > MaxLife® DEX/MERC ATF
They have many different types. just make sure it says mercon sp on the back label.
Recommended for use where DEXRON, DEXRON II, III and VI, Toyota T-IV and WS, MERCON®, MERCON® SP and LV, Allison TES 389, Nissan Matic-D, Matic-J and Matic-K, Honda Z-1 (except CVT), Mercedes NAG-1, Mitsubishi Diamond SP-II and SP-III and many others are required.
minnesotamadman
11-30-2005 12:56 PM
