cab mounts
If you are going to go that way - you might research JC Whitney - they used to have cab mount replacement boots that fit (bolted) over the existing - just an option if you are not trying to fit fit everything back factory
Not a great picture I know - but you can see what was installed on mine during the first restoration -
on
This is one of those areas of you get what you pay for!! Buy the better one's from Dennis Carpenter. Not the cheap $30 one like I did the first time around.
I've found the best way is to drill out all the old spot welds, I use grade-8 1/4"x3/4" bolts and fender washers on both sides. Just grind off as must of all the old slag or metal
so the new mount fits in it's place under the lip in at the fire wall area. I used a Clamp there to hole it while letting the cab down a little onto the rubber cab cushion for a good fit.
I Was sure glad, I bolted them in cause it made it easier remover the cheapo one's. The cheapo ones lasted about 3 yrs.. .my 2cent
orich
orich
on
My floor pans where rusted through in small holes here and their, I cleaned the pans good and used POR-15 with Boat cross weave fiberglass cloth, I used a 1/2 pint+ on each side.
The my floor pans are fixed for ever. Put about 1/4" built up of fiberglass on each side, put Por-15 ON the the bottom side once cleaned it good. When you don't have a welder any longer you got-a do the next best thing..Worked for me...orich
on
Por-15 had a little kit with a can of cleaner and all you needed. Wire brush the area good or use a de greaser then hose it off good let air dry completely or with heat gun. Put a thick base coast first then lay the F-glass cloth in place working the cloth into the por-15 in good with like a 4" bondo paddle working out all the air bubbles. For second coast let the Por-15 get some what tacky then apply more glass cloth over the same patch area over lap the base later. Add more por-15 as needed. I used the boat class cloth patch kit cross weave thick stuff.. You'll need some Lacquer thinner for clean up, This will stay on your hand for 4-5 days if you don't use a cleaner to remover it.. my 2 cents orich
on
My floor got wet for yrs and could not find the leaks other then wind wing areas. Then one summer day. I thought damn, I see if I can find any other places where it maybe leaking. I laid out news paper below the whole heater box foot areas and ran water on the out side wind shield seal area and little at a time and kept checking for wettest on the paper. None. So then put some water on the wiper arm shaft area and looked at the newspaper and bingo water was dripping in. Turns out the Wiper arm inner flange shaft gasket was split letting water into the cab floor. So you may have other leaking areas also. Good time to find them.
orich
orich
on
If you are going to go that way - you might research JC Whitney - they used to have cab mount replacement boots that fit (bolted) over the existing - just an option if you are not trying to fit fit everything back factory Not a great picture I know - but you can see what was installed on mine during the first restoration -
ymurf
02-18-2004 06:22 PM
