motor swap
motor swap
Hey guys a buddy of mine offered me a AMC straight six and a 3 speed trans that runs good I don't know to much about it will.know more on friday.... Thinking about puting it into my 56 f250 for the time being untill.I can get mine machined and put together when ever that will.be
The AMC 6 cylinder engines were pretty tough little engines. The one you mention sounds like it probably either came from a Jeep or IH Scout. Probably wouldn't be all that difficult to put in. Had a Scout with a 258 and 3 speed and it actually ran very well. My Jeep has a 4.0 which is basically the same engine. If it was free, runs good and you can do the work yourself go for it. You will probably be the only one with an AMC powered truck.
Paul
Paul
For a temporary measure, it will be a lot of work. Maybe the radiator inlet/outlets will work as-is, but motor mounts surely won't, and the stock engine uses bellhousing mounts for the main support. The AMC BH won't have those provisions so you'll also need a rear trans crossmember/support. Driveshaft, accelerator linkage, clutch linkage, fuel line, etc all need to be adapted or modified. Sometimes "free" really isn't.
84f2502122
12-05-2017 12:51 PM
