Flathead V8 idle problem
Old Dec 16, 2012 | 11:10 AM
Mike George's Avatar
Mike George
I have a '50 F5 with a fresh rebuild. Before the rebuild, I had a "surging" idle once the engine was warm. After the rebuild, it is still there. It cycles from normal idle speed to slow, normal to slow, every five seconds or so until it finally dies. Any speed other than idle it runs great. Fiddling with the idle mixture adjustment screws helps, but only for a few minutes and then they have to be readjusted. Any suggestions?
Old Dec 16, 2012 | 11:50 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Is your carb rebuilt? It sounds a lot like a leaking power valve, dripping fuel.
Old Dec 16, 2012 | 12:00 PM
Mike George
Yes, the carb has been rebuilt, about 2 years ago. Wouldn't a power valve problem cause backfires?
Old Dec 16, 2012 | 03:08 PM
ALBUQ F-1's Avatar
ALBUQ F-1
No, it just dumps gas into the engine without going thru the proper jets etc. The bottom side of it has a passage to intake manifold vacuum and if it leaks, you get a very rich mixture.
Try taking the carb off, and take the upper body off it. Fill the bowl with gas and leave it overnight with the lid on loosely. If the gas has leaked out, there ya go.
Are you using the stock fuel pump or electric?
Old Dec 16, 2012 | 05:32 PM
Mike George
It has a 6 volt pump. I have noticed, after driving several miles, a "whoosh" of air when I take off the tank cap. I'm so used to it on my modern cars I haven't been concerned; but, there should never be any vacuum in this age truck tank, right? If that was a factor, though, wouldn't it affect it at all engine speeds? I do lose fuel out the bowl, but it has always appeared to be leaking from the jet access plug. Maybe it is leaking at the power valve, too.
Old Dec 16, 2012 | 05:50 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Do you have a pressure regulator on the line to the carb? Holley 94's don't like high pressure at all, 2 - 2.5 psi is the most. Holley sells a very nice regulator just for older carb'd vehicles, model 12-804. Autozone sells it as do Summit, etc. Holley Fuel Pressure Regulators 12-804 - SummitRacing.com
No, you shouldn't hear any "whoosh" at all. It may be pressure (not vacuum) in which case it adds pressure to whatever the pump puts out.
Old Dec 16, 2012 | 06:39 PM
Mike George
I'll give it a try. Thank you for the advice.
Old Dec 17, 2012 | 04:44 PM
arctic y block's Avatar
arctic y block
Try running with the fuel cap loose and see what she does. Your cap should be vented and sounds like this one is not.
Old Dec 18, 2012 | 08:43 AM
cstempert's Avatar
cstempert
Check the plugs to see if it's running lean or rich.
Also check the throttle shaft, as it can be worn allowing air to leak by the shaft and cast-iron body. As the CI heats up gap gets larger, hence lean when warm.
If it's loose, you can solder the brass shaft and sand it back within spec. Many carbs get rebuilt, but not many have the shaft tolerances checked or rely on felt or rubber seal.
Old Dec 28, 2012 | 02:23 PM
Mike George
Thank you ALBUQ F-1! I've tried many things (found out the "vented" aftermarket gas cap was not vented at all; I put my rusty but functional original back on) but the fuel pressure regulator nailed it. I had to readjust the float level higher (a sure sign it was overfilling before) and not only is it idling beautifully, I am seeing an increase in acceleration in top gear and the gas mileage is now over 10mpg where it had been down around 7.5. Even though the plugs looked OK, it had to have been running rich. Thanks again for the suggestion. This is a great forum.
gordo2
Aug 31, 2015 11:01 AM
*70F250*
Jun 14, 2007 11:25 PM
andrewasl
Jul 7, 2006 11:06 PM
lilpig88
Feb 4, 2004 11:51 PM
dablack
Feb 21, 2002 08:41 AM
