1975 F 250 steering coulumn issue
Took the steering gear box off the truck and found a split in 2 ragjoint. That would be an easy fix. However, the flange on the column shaft ( the piece the ragjoint bolts to) moves up and down- which caused the clocking holes in the flange to wear, excessive steering play. Can i get bushings/bearings for the column and repair it? Can't seem to find any info at my regular parts place. Oh yeah, its a two wheel drive camper special with a 460, auto, 1975 F 250. Any help/info appreciated.
ghanaguy
ghanaguy
Check the illustration from the Ford parts catalog. Sounds like you need basic p/n 3C773.
Bushing, steering column shaft
Fits 73-77 F100-350 2WD from s/n S40,001
D3TZ-3C773-A replaced by D9TZ-3C773-A
D3TZ
Babb Ford Sales, Reed City, MI has 1 (231) 832-2206
Kinsel Lincoln-Mercury, Beaumont, TX has 1 (800) 816-2894
JST Automotive, Lebanon, TN has 1 (615) 443-3086
Wesley Obsolete Parts, Liberty, KY has 1 (606) 787-5293
Parts International, Farmers Branch, TX has 1 (972) 241-8730
D9TZ
Tison Motor Co., Estill, SC has 2 (803) 625-2551
D3TZ
D9TZ
onepeiceatatime
04-04-2007 09:20 PM
goldnickle
12-31-2005 06:23 PM
