33 pickup steering column?
Old Mar 12, 2010 | 07:12 AM
redwhiteandblue's Avatar
redwhiteandblue
Before we tear this apart, does it use bearings or the rubber bushings like the cars? Are there lube points for it? Steering is very difficult and tracked down to the column. Any info and part sources appreciated! Thanks, Tom.
Old Mar 13, 2010 | 03:52 PM
Steve Christensen's Avatar
Steve Christensen
Don't know about a '33 column, but my '42 truck had a rubber bushing in the top of the column. I made a nylon bush and pressed it in. There are no lube points on a '42 column. Regards, Steve.
Old Mar 13, 2010 | 04:35 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Welcome to FTE
The steering is difficult, because: The steering shaft & worm are prolly worn, as is the sector shaft. The two steering shaft and worm bearings are history, as is the sector shaft bushing.
Fords over the years are notorious for having p!ss poor steering gearboxes. I seen some that were so worn, the steering wheel had one foot of play in it. 4 to 6 inches of play is common.
Parts for the steering gearboxes are available from those that specialize in early Ford parts, for example: Dennis Carpenter, Bob Drake, C&G Ford Parts, Sacramento Vintage Ford, Early Ford Store.
Go on ebay and get yourself a copy of what we flathead nuts used to call The Bible > > The 1928/48 Ford Passenger Car & Truck Parts Catalog.
This catalog is also available from the sources I listed...who also have catalogs of their own for what parts they sell.
Old Mar 14, 2010 | 11:38 PM
banned's Avatar
banned
I ran a 2 piece 35 box for 5 years and learned why they suggest using a 37 to 48 box......
Old Mar 18, 2010 | 07:34 AM
redwhiteandblue
Will a newer (37~42) box bolt in to replace the original? This will get a rack but not until the small block is evicted from the Truck and replaced with a flathead that we are working on. The steering is tight, just have to stand on it to turn the wheel! Thanks guys.
Old Mar 18, 2010 | 10:13 AM
banned's Avatar
banned
the bolt holes are in different.places
you can use a 37 to 48 mounting plate or make something
carolinaskifftom
1983 - 2012 Ranger & B-Series
Jan 8, 2012 07:48 AM
ymurf
Mar 20, 2004 09:01 AM
Tom
Jan 25, 2000 02:52 PM
Tom
Jan 16, 2000 10:29 AM
