1967 F100 4BT cummins daily driver build
Old 11-25-2012, 07:41 AM
f100today's Avatar
f100today
f100today is offline
So I have been working on this since July now. I think I finally have gotten far enough to start a thread on it. This is going to be my daily driver. Cummins 4bt with compound turbo set up, "beefed up" mustang II front suspension, Phoenix transmission diesel specific built 700R4 OD tranny, dodge steelies, and fully boxed frame.
So here it goes.......
removing the I-Beam suspension
Old 11-25-2012, 07:44 AM
f100today's Avatar
f100today
Boxing the frame, fabbing up the mustang II...........
Old 11-25-2012, 07:51 AM
f100today's Avatar
f100today
Installing mustang II and some of the upgrades........
Beefed up speedway motors lower control arms; added gussets and larger ball joints.....
Old 11-25-2012, 07:59 AM
f100today's Avatar
f100today
welding the MII in..............
Old 11-25-2012, 08:04 AM
f100today's Avatar
f100today
finishing up the front suspension. I didn't like the extended length tie rods so I put some heim joints and billet tie rod sleeves on. 700lbs springs with QA1 coil overs.
Old 11-25-2012, 08:10 AM
f100today's Avatar
f100today
And on to getting the motor mounts fabbed and the cummins in the chassis. And yes, you are seeing that right; the engine is set waaaay back and I cut the firewall. I will have to modify the windshield wiper mechanism a little, do a street rod gas pedal set-up, and some custom carpet.
Old 11-25-2012, 08:13 AM
f100today's Avatar
f100today
So this is where I am at. Engine is set in the chassis and the cab is in place. I will post pics of the rear frame work next weekend.
Old 11-25-2012, 10:14 AM
68cabby's Avatar
68cabby
68cabby is offline
Subscribed. That's awesome!
Old 11-25-2012, 10:22 AM
jowilker's Avatar
jowilker
jowilker is offline
I have a question of my own ignorance, why did you set the engine so far back? I think I am aware that the newer trucks are similar, but is there a reason?
The transmission bell is out in the engine bay on my slick.
John
Old 11-25-2012, 11:11 AM
f100today's Avatar
f100today
John
Couple of reasons; The first being that the mustang II was never designed for something with this kind of front end weight. That motor weighs 750 lbs, then add two turbos at about 75lbs for both, then add a big inner cooler and a big radiator and it adds up quick. That is also why I tried to address the weak points of the suspension. Second, the further back you set a motor toward the cg of the vehicle, the better it will handle and ride. Third, I wanted ample space for those turbos, inner cooler, and radiator. And fourth, just to say I did it; I cherish a challenge and I am not a "bolt in" kinda guy. I love fabricating stuff, half the time for unnecessary reasons.
Old 11-25-2012, 07:14 PM
Ford_Six's Avatar
Ford_Six
Ford_Six is offline
That is a clean build. As a bonus you have no worries about making that tall engine and the crossmember or steering get along.
Old 11-25-2012, 07:33 PM
grinnergetter's Avatar
grinnergetter
grinnergetter is offline
Nice fabwork!!!
How much space are you going to have in between fan and rad? Looks like ALOT!!!
Old 11-25-2012, 08:41 PM
sniswend's Avatar
sniswend
sniswend is offline
Sweet build! subscribed
Old 11-25-2012, 09:02 PM
crewcabfan's Avatar
crewcabfan
crewcabfan is offline
Wow! You sir are a clean welder and superb fabricator
Subscribed.r
Old 11-25-2012, 09:53 PM
carchub's Avatar
carchub
carchub is offline
Man! This makes me want to learn how to weld so bad! I'm glad I found that weld tutorial in the older truck thread
Quick Reply: 1967 F100 4BT cummins daily driver build
